70 z28 exhaust ?
Discussion in 'Camaro Questions' started by ralph amitrano, Jan 25, 2021.
  1. badazz81z28
    19,915
    1,209
    Alabama
    It doesnt look like any special clamp is going to solve your issue....the clamps you have should work fine. I agree, welding is the best option to seal it up.
  2. ralph amitrano
    ralph amitrano Veteran Member
    166
    11
    Dec 15, 2017
    Ok thanks badazz
  3. Jodi
    Jodi Veteran Member
    723
    423
    May 22, 2019
    I preferred this type of clamps over the u bolt type... seals 100% and doesn't distort the pipe, makes it easier for disassembly after. Plus it just looks so much nicer.
    This won't work if the pipe is distorted though, if the pipe is distorted due to being crimped by a U bolt clamp such as in your case, it must be straightened first by using a pipe expander tool.
    Z-Life likes this.
  4. mallard
    mallard Veteran Member
    998
    284
    Oct 3, 2013
    SK, Canada
    Does the lack of a relief hole in the muffler play a role? Mufflers so far to the rear of the exhaust system tend to not get hot enough to burn off the excess moisture especially on antique cars with limited driving time.
    berg2695 likes this.
  5. ralph amitrano
    166
    11
    Dec 15, 2017
    Thanks Jodi nice clamps I'll look in to them.
  6. 70-camaro
    70-camaro Veteran Member
    3,167
    1,415
    Mar 25, 2010
    marietta ohio
    I am also using these. If I remember right I got the from Pypes.
  7. 70lt1z28
    4,099
    928
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Not sure how those clamps work when close to a bend. Do they? Seems like they would need a minimum amount of straight pipe. It looks like the OP's pipe starts the bend right out of the muffler.
  8. Jodi
    Jodi Veteran Member
    723
    423
    May 22, 2019
    They do come in different widths...
    If the OP decided to go this route, he could pull the pipe from the muffler a little to lengthened the straight part of the pipe and then seal it with this clamp.
    70-camaro and 70lt1z28 like this.
  9. COPO
    20,114
    2,019
    I wonder if high temp exhaust sealer would work if you jammed it into the cracks if tightening the clamps doesn’t work.
  10. Sunny Z/28
    Sunny Z/28 Member Gold Member
    65
    31
    Jun 7, 2020
    Get it welded, take some steel wool to that surface rust and be done with it.
