700-R4 Pan Gasket?
Discussion in 'Transmission & Driveline Topics' started by CorkyE, Sep 15, 2020.
  1. CorkyE
    10,865
    664
    I ordered a GM filter for the transmission. It came with two gaskets, a paper coated and a cork gasket. Paper is for a continuous raised rib oil pan, cork for non continuous. These are for the stock stamped steel pans. I'm running a cast aluminum deep pan with a smooth face surface all the way around. So, would the paper or cork be better in my application, and is any type sealant recommended? Thanks
  2. tom3
    tom3 Veteran Member
    12,900
    724
    Aug 1, 1999
    ohio
    I don't like any sealer in the auto trans. gaskets, and I'd use cork on that pan.
  3. CorkyE
    10,865
    664
    Thanks Tom.
  4. Twisted_Metal
    28,108
    1,554
    Forget the gasket and use "The Right Stuff"!
    It will seal it good but taking the pan off in the future may require a hammer and chisel. ;)
    Seriously... I would use the cork gasket since the pan has a smooth surface.
  5. CorkyE
    10,865
    664
    Good deal, thanks Terry.
  6. 80sz
    80sz Veteran Member
    3,426
    509
    Feb 2, 2014
    Buffalo,n.y.
    My 2002 got cork and no leaks. I use some red tack also
  7. Twisted_Metal
    28,108
    1,554
    ^Good Tip!
    Clean both surfaces with brake cleaner.
    A little bit of "tack" to keep the gasket situated during assembly and torque the bolts to spec. (9 ft/lbs)
    Personally... I will use a "LubeLocker" gasket on my transmission pan the next time I do a fluid/filter change.
    https://www.summitracing.com/parts/lub-llt-g4l60
    With a cast pan and these gaskets... The pan should NEVER leak.
    I just need a cast pan for my 200-4R and they are over $200. :(
