700r to ford 9 inch
Discussion in 'High Performance Modifications' started by Hogg jr, Sep 14, 2021.
  1. Hogg jr
    Hogg jr New Member
    12
    Nov 22, 2016
    I have a 700r and just put a ford 9inch in my 70 camaro it has the short yoke I belive 1310 ujoint any idea of length drive shaft I need or one I can Pull out of junk yard
  2. 1980RS
    1980RS Veteran Member
    5,516
    1,817
    Jun 17, 2006
    MN
    Every combination is different. You will need to measure from the center of the u-joint cup on each end to get the right measurement, then you can go to the junk yard to find something but I would build a new one as then it's right to start with.
    hubedobeedo and Hogg jr like this.
  3. Jodi
    Jodi Veteran Member
    876
    599
    May 22, 2019
    Just an FYI...on my '73 with a TH400 (short shaft) and 9 inch(1350 U joint) combo the distance between the center of the diff U joint and the transmission tail shaft housing seal is 52".
    Hogg jr likes this.
  4. Hogg jr
    Hogg jr New Member
    12
    Nov 22, 2016
    Do you know if the yoke on the 9inch is a long or short yoke
  5. Jodi
    Jodi Veteran Member
    876
    599
    May 22, 2019
    Overall length is 4.063" so I'm leaning more to short.
    3rd member assembly is from Strange.
    hubedobeedo likes this.
  6. muscl car
    23,346
    1,789
    Jul 8, 2001
    Hendersonville Tennessee
    Here's my Ford 9" center section from Quick Performance
  7. Hogg jr
    Hogg jr New Member
    12
    Nov 22, 2016
    Short yoke
  8. Hogg jr
    Hogg jr New Member
    12
    Nov 22, 2016
    Mine came from speedway motors
  9. hubedobeedo
    hubedobeedo 3rd times a charm
    687
    259
    Jul 18, 2013
    Huntertown,IN
    i had a local clutch shop build mine 1320 ends moly DOM tube (3INCH) solid u joint 1320 all USA parts i refinished before install . i got strange nodular center on my 9 from quick performance billet pinion and housing .the shop had a questionnaire that had specific things they needed to make.
    Hogg jr likes this.
  10. 73Z L92
    73Z L92 Veteran Member
    243
    94
    Jan 25, 2011
    Carlos, MN
    If it's not too late I would go with a 1350 u-joint trans slip yoke. I would upgrade the 9" yoke to a 1350 u-joint.
    Hogg jr likes this.
