700r4 Overdrive
Discussion in 'Transmission & Driveline Topics' started by Dennis Wilkie, Nov 23, 2021.
  1. sandlapper
    sandlapper Veteran Member
    995
    395
    Oct 9, 2020
    SE CSA
  2. Dennis Wilkie
    Dennis Wilkie Veteran Member
    443
    43
    Mar 17, 2020
    I'm convinced this truck is possessed. I plugged the tcc back in a little while ago just to see what it was gonna do before I decided to take it back down, and it drove like it did when I first put it all back in. Shifted through all of the gears and went into overdrive like it's supposed to, and never even gave the impression that it was going to vibrate. All i've done is check the voltage at the pigtail, and adjusted my choke and fast idle screw on the carb. At idle, it showed just under 12.99v. This thing is determined to kill me, lol.
  3. CorkyE
    11,526
    974
    Hopefully it continues to act right. Just info, you don't need to pull the transmission, just drop the pan to check the switch I referenced.
