700r4 rebuild attempt
Discussion in 'Transmission & Driveline Topics' started by Dennis Wilkie, Apr 15, 2021.
  1. Dennis Wilkie
    Dennis Wilkie Veteran Member
    375
    38
    Mar 17, 2020
    Well, apparently the kit came with the wrong size extension housing bushing and seal. So now i've got to order them and wait another week for it to get here....good times
  2. Dennis Wilkie
    375
    38
    Mar 17, 2020
    But in the meantime....
  3. camaro71/holland
    1,518
    207
    Aug 27, 2003
    The Netherlands
    Good job. If you still need to replace the (two) rings on the back of the pump (stator), leave them off while measuring the front end play. Makes the job easier and you won't damage them.
    And air check the servo from underside of the case.
  4. Dennis Wilkie
    375
    38
    Mar 17, 2020
    Ok...so, i've got everything back inside the bellhousing and the pump torqued to 18 ft lbs. Now i'm about to put the check balls and gaskets on, and the manual is saying not to put the bigger one back in, but doesn't specify why. I circled all of the check balls and circled the bigger one in red. Also, I keep being told there are supposed to be 7, and I only have 6, and i'm positive that's how many were there when I opened it up. Unless they're referring to the recessed ball that didn't come out, there's not a 7th ball.
  5. Dennis Wilkie
    375
    38
    Mar 17, 2020
    Also, these 3 never came out of the valve body, and that gasket has been there the whole time. I've got the 2 gaskets on both sides of the steel plate, and there are 2 more gaskets in the kit. I assume they're for a 4L60e
  6. Dennis Wilkie
    375
    38
    Mar 17, 2020
    Just got it and the new torque converter back in last night. Still waiting on the transfer case gasket I ordered, and the new intake manifold to get here before i'll get to try it out. As soon as I finish up the tbi to carb swap, i'll post another update
