700R4 Transmission Pressures
Discussion in 'Transmission & Driveline Topics' started by Bandit723, Nov 20, 2020.
  1. 77 cruiser
    77 cruiser Veteran Member
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
  2. Twisted_Metal
    29,491
    2,389
    The pressure should raise as soon you move the accelerator above idle.
    Starting at too high of pressure and sneaking it downward is the safest way to get it right.
    Glad you got it adjusted correctly!
  3. Bandit723
    Bandit723 Veteran Member
    3,529
    619
    Oct 1, 2016
    Waupaca WI
  4. 77 cruiser
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
    The cable has to be tight at WOT, if the geometry is right that's the only way to do it.
  5. 80sz
    80sz Veteran Member
    3,845
    713
    Feb 2, 2014
    Buffalo,n.y.
    See ya modified the tvcable bracket ...lol.
  6. camaro71/holland
    1,488
    194
    Aug 27, 2003
    The Netherlands
    The cable should be tight from the beginning on.... if not, it's operating nuffin.
    You want a pressure rise even with a slight touch of the accelerator, so it needs to pull the cable/depress the tv plunger in the case.
    At WOT the plunger needs to be depressed all the way into the VB.
    77 cruiser likes this.
  7. 77 cruiser
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
    Exactly should have said fiddle string tight. Yes you need rise at movement of the throttle.
  8. Bandit723
    3,529
    619
    Oct 1, 2016
    Waupaca WI
    does it matter cable pulls straight.
  9. Bandit723
    3,529
    619
    Oct 1, 2016
    Waupaca WI
    Reason i put the line pressure gauge on was to be sure the 1. the trans was pumping out enough pressure thru the gears 2. was to make sure the cable got adjusted out correctly on the idle side. As folks have said you want the rise to happen just as you crack the throttle. What i have seen there can be quite a gap from when adjusting the cable on the idle side. This trans has about a 3/4 inch pull before seeing a rise in pressures. I could have easily miss adjusted it.
  10. 80sz
    80sz Veteran Member
    3,845
    713
    Feb 2, 2014
    Buffalo,n.y.
    The tv cable travel could be off depending where the cable pulls from with the arc being different
