700R4 Transmission Pressures
Discussion in 'Transmission & Driveline Topics' started by Bandit723, Nov 20, 2020.
  1. Bandit723
    Bandit723 Veteran Member
    3,529
    619
    Oct 1, 2016
    Waupaca WI
    Now you got me looking at this again. WOT the geometry is right but from idle the cable does move but not a whole lot until the cable straightens out. I do have the Holley corrector shown on the right of this picture but might be a older version? Not sure what the part number is for the one on the left is "
    20-121" ?
    but i will try an order one.
  2. 80sz
    80sz Veteran Member
    3,845
    713
    Feb 2, 2014
    Buffalo,n.y.
    The one on right looks correct , that’s what I was thinking , it’s sorta like a pump cam motion in pump squirters
  3. Bandit723
    3,529
    619
    Oct 1, 2016
    Waupaca WI
    O'Reilly's is able to get me the one on the left will be in tomorrow. Guess i will see what i get once i try it out.
  4. 77 cruiser
    77 cruiser Veteran Member
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
    80sz likes this.
  5. Bandit723
    3,529
    619
    Oct 1, 2016
    Waupaca WI
    New corrector came in did change things up. Cable looks to be a bit more straight and does get more travel right off the bat. I did have to adjust it again to gain the full extend for WOT. At idle pressure looks to be at 75 psi which jives with the chart. Reverse is 115 PSI and 2nd and low is at 180 psi.
    Only bear is the rod that controls the flaps on my bug catcher won't clear the cable "always something" pretty sure i can drill a new hole and relocate it.
    80sz likes this.
  6. pomartin
    pomartin Veteran Member Gold Member
    199
    29
    Sep 16, 2019
    Oh i still remember the nightmare I went through crafting the correct geometry for my pre-Holley acquisition demon, there was always that other thing that needed to be adjusted due to bracket change :p.
    Useful tip: pressure will vary with oil temperature quite some, so make sure you start measuring procedure always at the same oil temperature and use the same procedure- this way you will get data that you could actually compare between tests.
  7. Bandit723
    3,529
    619
    Oct 1, 2016
    Waupaca WI
    Good tip. Hopefully the weather clears up tomorrow so i can spend some quality on this thing.
  8. Bandit723
    3,529
    619
    Oct 1, 2016
    Waupaca WI
    ok played around with the Trans this morning went for a short roll with the idle pressures at 75psi did not feel good so pulled over and readjusted back to 90 psi at idle trans went back to acting normal so sticking with caution to the wind and will leave it there. Also futzed with trying to relocate bug catcher butterfly rod. not liking anything i can do on the fly.
