70-camaro
I have been looking for a 200r4 for quite a while and have had no luck. I have an opportunity to barter a power glide trans I have with 56000 miles on it for one of two 700r4 trannys.
One is out of a 89 Z28 the other out of a 87 Corvette. Both have 40xxxx miles. I know the Corvette 700 has heavier duty internals and different tail housing and if I want the vette trans I can swap the tail housings. Also look for the V on the housing of the Corvette trans. From my research 87 and later are the years that are best. Question is will the 700 hold up as well as a 200r4? I am running a 355 rearend gear and 350 turbo now and at 65 mph I am turning 3200 rpm and would like to get that rpm down. I know about shortening the drive shaft,tv cable and probably need Lokar products for this.
Sorry for rambling. Any help would be appreciated
