70zrs barrett jackson
Discussion in 'Original Drivetrain Topic' started by ren70z, Apr 14, 2018.
  1. 70lt1z28
    3,644
    734
    Oct 3, 1999
    Beavercreek, Ohio, USA
    And for that the automatic was probably more interesting than a 4 speed.
  2. bkmont
    bkmont Veteran Member
    1,165
    82
    Nov 14, 2010
    Pensacola, Florida
    I'll have to admit, from a cruising stand point which most of these cars are subject to, the auto is a nice convenience for us guys with the old legs:).
  3. 1970_Z28_503
    1970_Z28_503 Veteran Member
    122
    14
    Apr 12, 2017
    Oregon
    I have a 05D norwood car Vin is 1847 after this car, my block casting date is D280 April 28, 1970. Yellow car had D60 for casting date. Struck me as odd that they would burn thru 22 days of LTI engines in same week.
  4. 70lt1z28
    3,644
    734
    Oct 3, 1999
    Odd it is. They wouldn't have. The car had a replacement block that was the same type, meaning a 3970010 block with a "close enough" date code. Close enough meaning as long as it wasn't cast later than the cars build date it was in this case OK to the restorer.
  5. CamarosRus
    CamarosRus Veteran Member
    8,506
    141
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    I know Ive mentioned this multiple times........but Im the member who ordered
    a NEW 70 Z28 with a COLUMN SHIFTED Auto. (One of how many ???)
    I never realized it when I owned it , that the M-40 had the 6 Bolt Convertor
    with ?? stall and a tweaked valve body ...different that "ordinary" T-400.
    (same as LS-6 Chevelle)
    It was A LOT of fun to play with when I owned it from 1970-72ish ????
    After mods I got it to run 12.9's at Pacific Raceways, Kent,WA
