71 Camaro Doors
Discussion in 'Body Restoration' started by Dcmusch, Aug 10, 2017.
  1. Dcmusch
    Dcmusch New Member
    27
    Aug 21, 2014
    San Antonio, tx
    Will later model second gen door fit my 71? I need a passenger door, its at the paint shop and cant be saved. Previous owner did a killer bondo cover up and epoxy primered it. Didnt catch it until the car was stripped down.
  2. Double J
    Double J Veteran Member
    411
    15
    Jan 23, 2008
    Michigan
    Yes it will fit, their are internal structural safety differences (crash bar) but outward appearance is the same.
  3. 70-camaro
    70-camaro Veteran Member
    3,054
    1,235
    Mar 25, 2010
    marietta ohio
    Welcom to the fun. I put 77 doors on my 70 and the strikers didn't line up with the door latch. I bought a pair of 71 doors from my uncle in Arizona and problem solved. Also the interior door handles are different and you would have to use the newer handles. Screw holes were different for mounting the interior door panels. This all can be corrected by drilling new holes and if you want to use your 71 door handles you can cut out the area of door handle mounts and well in new. I have heard of guys cutting out and moving the strikers and rewelding in too. You may be better off to reskin them.
  4. Twisted_Metal
    28,470
    1,793
    If the shell can be saved... Reskinning is a good option to consider.
  5. Custom 68
    Custom 68 New Member
    19
    Mar 20, 2015
    Springfield Missouri area
    I am new to all this second gen but I ended up with a "newer" door that the lower part about 3 or 4 inches from the bottom was different? My 71 has lower doors that have a body line the one I ended up with did not. Was this a Firebird door I ended up with or what was different?
    Thanks
    Dave
  6. 70-camaro
    3,054
    1,235
    Mar 25, 2010
    marietta ohio
    Must be a Firebird door. You being in Texas you may be able to find a nice door within a couple hundred miles.
  7. Dcmusch
    Dcmusch New Member
    27
    Aug 21, 2014
    San Antonio, tx
    My paint guy said the skin would work at first too, nows he's telling me he wants to find good original door. I just think they are gonna be hard to come by.
  8. 1971CamaroGuy
    3,792
    186
    Oct 31, 2004
    I have 76 doors on my 71..worked fine. You can see them in my build thread
    Don't blame your body guy not wanting to use a door skin, pain in the ass to install and get to look right, and even installed those doors edges will still need to be re-worked, maybe even more so with skins
