71 RS - abandoned 23 years
Discussion in 'Project Progress' started by Chuck71RS, Nov 24, 2012.
  1. 70 Proof
    70 Proof Veteran Member
    567
    62
    Sep 28, 2014
    Southern Utah
    Chuck
    "Adapt and Overcome" should be your motto
  2. Chuck71RS
    1,673
    296
    Nov 24, 2012
    Houston, Texas
    As of 12 May 2019, 4:45 pm, I finished the exterior spraying of my 1971 Camaro RS. A lot of problems along the way resulting in a lot of do overs but it now looks DARN good...!! Contamination is present but will be removed with 2000 grit then buffed, which will also remove orange peel. Will look even better.
    Reluctant to paint your own because you have never done so before? You can do it for I was nervous, heck even scared to do so for I had never picked up a spray gun before. But with a lot of help from this group, in the form of Xten, I did it. A lot of emails and phone calls without which I would not have been able to do this. Thanks Phil. Tremendous satisfaction and yes pride in the result
    Spraying direction was up from bottom to top, move right, top down to bottom, move right, repeat.
    Continued in next post
    71RSLS, xten and bodymanbill like this.
  3. Chuck71RS
    1,673
    296
    Nov 24, 2012
    Houston, Texas
    100_7933.JPG 100_7933a.JPG 100_7934.JPG 100_7935.JPG 100_7935a.JPG 100_7935b.JPG 100_7936.JPG 100_7940.JPG 100_7941.JPG
    71RSLS and bodymanbill like this.
  4. Chuck71RS
    1,673
    296
    Nov 24, 2012
    Houston, Texas
    Last painted parts
    71RSLS likes this.
  5. Chuck71RS
    1,673
    296
    Nov 24, 2012
    Houston, Texas
    Readying Interior Parts for the new color: Will be close to the color or the new headliner material. Anxious excited to see the new color. 28 pieces total to spray
    Below group (+ RH kick panel) will first be sprayed with SEM High Build then SEM Texturizer. HB is to get a uniform surface for areas have worn off factory texturizer or I sanded off to remove damage.
    Needed mesh on both sides along with Permatex Plastic Welder.
    The ac vent turned upside down looks is a helmet from the middle ages
    Will add padded arm rests and a similar padded part to the vertical concave surface. Will use gray vinyl sprayed with the new color. Doing this to dress up the panels
    Would not work but looked into fiberglassing the horizontal seam between the two rear panels. Would look better without the seam
    Already primered
    Door pulls cut from the lower door panel for use with the single piece 78 Legendary panels.
    Front and back ends enclosed
    Did not enclose the underside. Removed the 5 strengtheners then a piece of ABS plastic to cover the area
    71RSLS likes this.
  6. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,577
    1,043
    Mar 27, 2016
    NY
    Looks really nice, you are an inspiration, for the rest of us , who are afraid to paint!!
  7. DBS
    DBS Veteran Member
    366
    14
    Sep 24, 2014
    Belzoni MS
    Looks good chuck
  8. wnmech
    wnmech Veteran Member
    1,254
    247
    Jul 20, 2014
    grand prairie tx.
    Chuck looks great
  9. BillyDean7173
    BillyDean7173 Spirit In Black
    2,645
    880
    May 21, 2014
    Hutto, TX
    Great job, Chuck! Looking forward to coming down in two weeks.
  10. 71RSLS
    71RSLS Veteran Member
    766
    176
    Dec 5, 2017
    Prairie City, Ia
    Chuck, it looks great and nice work on your interior! What are you using to redye your panels etc?
