'71 Virginia Camaro
Discussion in 'Project Progress' started by ffshu, Nov 12, 2011.
  1. ffshu
    ffshu Veteran Member
    251
    Mar 22, 2011
    New Kent Virginia
    So I'm doing one rail at a time and I started this evening cutting spot welds, either with a spot weld bit or a cut off wheel. The plasma cutter makes nice work to get the bulk of the frame out of the way and all I have to work on is the lip with the spot welds in it.
    This will be a slow process, but it will be a big accomplishment to get this part done. The trunk pan will go in after they are in place.
  2. brooksman9
    brooksman9 Veteran Member
    6,283
    299
    Jun 10, 2007
    Olive Branch, MS
    Lookin good.
  3. ffshu
    251
    Mar 22, 2011
    New Kent Virginia
    Well I got to work on the car for a little while yesterday, and my wife and daughter are not feeling well today, so I might be in the house most of the day, but I did get almost all of the driver's side frame rail off. It is a slow process removing those damn spot welds :mad: I'm able to grind some and drill the rest, so it's slow, but getting there without doing any other damage.
  4. camaro6662
    camaro6662 Veteran Member Lifetime Gold Member
    769
    Feb 29, 2004
    Jackson Ga
    nice job
  5. Da-bigguy
    5,640
    1,561
    Jan 19, 2010
    Cypress, TX
    That is nice work!
  6. Double R Restorations
    2,554
    34
    Jan 11, 2002
    Looks great, it takes a lot of time to remove these panels without doing a lot more damage. I have to replace the lower right side on mine. You are doing a great job.
  7. ffshu
    251
    Mar 22, 2011
    New Kent Virginia
    Thanks for the compliments guys. It's coming along slow, but this is one of those repairs that needs to be done right or the whole thing will be screwed up. Maybe a little garage time today after my laundry list of things to do.
  8. BP80Z28
    BP80Z28 Veteran Member Lifetime Gold Member
    1,153
    Sep 2, 2008
    Plymouth Mass
    Nice work!! Hats off to you guys that do this major panel replacement.:bowtie:
  9. clay's70
    clay's70 Moderator Staff Member Lifetime Gold Member
    2,187
    126
    May 3, 2008
    Chesterfield, VA (Richmond)
    Same here!! I'd just screw that up
  10. ffshu
    251
    Mar 22, 2011
    New Kent Virginia
    Clay.....................where have you been???
