Eric winkel
- Mar 3, 2021
- 62
One issue with a leaking diaphragm on replacement pumps is that many of them omit the small vent holes that were on the original pumps. When the diaphragm leaks, the gas has nowhere to go but into the engine instead of leaking out. If enough gas goes to the oil pan it can do two things, dilute the oil enough to take out the bearings or build up enough fumes to eventually combust and blow the pan or valve covers off.I put an old used pump that my buddy gave me on my rebuilt 350 and about a month later it leaked through the diaphram. Todays gas causes all kinds of issues on our old stuff. Also the gas ruined the pump on my HenryJ.
My old pump has 2 vent holes above the diaphragm which is how I knew it was shot. The other old stock I put on also has the 2 vent holes, will see if it goes bad. Just finished putting in an electric near the tank just in case.One issue with a leaking diaphragm on replacement pumps is that many of them omit the small vent holes that were on the original pumps. When the diaphragm leaks, the gas has nowhere to go but into the engine instead of leaking out. If enough gas goes to the oil pan it can do two things, dilute the oil enough to take out the bearings or build up enough fumes to eventually combust and blow the pan or valve covers off.
