72 Camaro SS street - strip build
24,185
Gallatin Tennessee
My old build thread i had to delete due to watermarked pics from a pic hosting site so I decided to start over
Well anyways this is my 72 Camaro ss that I've owned since 1999 . Slowly over the last few years I've been building it into a Street - Strip build
Here's a couple of pics of my Camaro from a local car show a couple years ago
24,185
Gallatin Tennessee
The front and rear suspension is set up for drag racing
Front suspension ...
Moroso Trick front springs
QA1 double adjustable drag racing shocks
15x3 Weld Drag lites mounted on 26x7.50/15 MT Sportsman front runners
Rear suspension ....
Full Calvert racing rear suspension with Calvert split mono leaf springs , Calvert racing Cal tracs and Calvert racing single adjustable shocks
15x8 Weld Drag lites mounted on 275-60/15 MT Drag radials
To stiffen up the chassis even more Competition Engineering subframe connectors were welded in . The cage was tied into the subframe connectors and body mounts and rocker panels
24,185
Gallatin Tennessee
Pic of the interior .....
MSD 7AL2 Ignion box
Hurst Quarter stick ( reverse manual valve body pattern
Biondo adjustable Pro tree Transbrake button
Autometer sport comp monster shift lite tach
Autometer sport comp 2-5/8 gauges
Mech oil pressure
Mechanical water temp
Trans temp
24,185
Gallatin Tennessee
Mikes Transmissions Lancaster Ca
Ultimate T350 Race transmission capable of supporting 800 plus hp
Heavy duty billet parts from Coan built to my specs including full manual reverse valve body and Pro tree Transbrake
Custom built to my specs 8" 4500 stall converter with anti balloon plates
24,185
Gallatin Tennessee
Scott Shafiroff racing engines 427sbc
https://www.shafiroff.com/chevy-pump-gas-short-block/427-short-block-street.php
Engine specs ...
Shafiroff racing 427sbc 565 plus hp /575 tq
Dart block splayed 4 bolt main caps
4.125 bore / 4.000 stroke
SSRE / Manley 4340 steel crank
Manley 4340 6.000" H beam steel rods
Mahle 9.5:1 forged pistons / 10.25 compression with 64cc cyl heads
SSHHR Hydraulic roller cam 243/251 @ .050 .595/.598 lift 110 lsa
AFR 195 Cyl heads that have been cleaned up / ported
7/16th studs
Crane Gold race roller rockers 1.6 ratio
Isky 8005A valve springs .650 lift with titanium retainers
Edelbrock Super Victor intake
1" tall Wilson tapered spacer
AED 850 Carb built to my specs
Hedman Huslr 1-7/8 headers
24,185
Gallatin Tennessee
AFR 195 cyl heads , and as per Shafiroff racing reccomendations Isky #8005A valve springs .650 lift and titanium retainers and 7/16th ARP studs . The cylinder heads were massaged and cleaned up while new springs and retainers were installed
