72 Camaro SS street - strip build
Discussion in 'Project Progress' started by muscl car, Oct 17, 2020.
  1. muscl car
    23,236
    1,677
    Jul 8, 2001
    SoCal High Desert
    The Ford 9" has much more aftermarket support plus the best axle retention . Also the main selling point is the easiest or quickest gear change
  2. muscl car
    23,236
    1,677
    Jul 8, 2001
    SoCal High Desert
  3. muscl car
    23,236
    1,677
    Jul 8, 2001
    SoCal High Desert
    Just cleaned up my 8 point roll cage with 800 grit sand paper then wiped down with silicone spray and a clean cloth
    I do this 2x's a year to keep it looking nice
    20210305_132848.jpg 20210305_132833.jpg 20210305_132807.jpg 20210305_132645.jpg 20210305_132618.jpg
    geoman, roadrace2 and Jodi like this.
  4. Jodi
    Jodi Veteran Member
    809
    522
    May 22, 2019
    That's a good idea!
    muscl car likes this.
  5. muscl car
    23,236
    1,677
    Jul 8, 2001
    SoCal High Desert
    Keeps the chromemolly tubes looking clean !!
  6. Jodi
    Jodi Veteran Member
    809
    522
    May 22, 2019
    For sure...mine is painted, it has scratches that requires some touch up.
  7. muscl car
    23,236
    1,677
    Jul 8, 2001
    SoCal High Desert
    Quick Performance 9" axle installed !! :)
    The D/side caliper was not the correct part# from Quick Performance and they're sending me the correct part and should be here by next week . The brake lines are braided stainless steel and will work very well
    The axle was very easy to install and the heavy duty spring perches mounted to the Calvert racing split mono leaf springs with no issues . The pic shows oil all over the shocks but the shocks are not damaged . The oil is from a bad pinion seal on my old GM 10 bolt
    and the shocks have been cleaned
    The driveshaft is being ordered tomorrow
    roadrace2, Jodi, geoman and 2 others like this.
  8. muscl car
    23,236
    1,677
    Jul 8, 2001
    SoCal High Desert
    Driveshaft ordered !!!
    Decided to go with 3.5 dia Chromemolly tube and billet 1350 yokes on ea end and solid 1350 u joints
    Was told by the shop making the driveshaft this design / setup will support over 900 hp
    Zstar likes this.
  9. Jodi
    Jodi Veteran Member
    809
    522
    May 22, 2019
    I ordered similar driveshaft from Strange Engineering, still waiting...apparently they don't have any hardened slip yoke required for my TH400 (tail shaft roller bearing) at the moment.
    Should be a robust one and more importantly, it shouldn't exceed its critical speed.
  10. muscl car
    23,236
    1,677
    Jul 8, 2001
    SoCal High Desert
    That sucks , hopefully your back ordered parts become available . I was told my driveshaft is 2.5 weeks out from being completed . The shop I'm having mine built is a well known here in the Desert racing community and builds driveshafts for Trophy trucks
    The shop owner was telling me the chromemolly/ billet driveshaft will work very for my combo
