72 tall spoiler
Discussion in 'Body Restoration' started by broahnazki, Oct 8, 2017.
  1. broahnazki
    broahnazki Veteran Member
    259
    63
    Jan 19, 2014
    los angeles
    C36259A0-4F07-4292-BE83-CD2842970E2B.jpeg B37A1F73-C3C6-4D84-9B6F-605DF12CA376.jpeg So the center part of the 3 piece is taller. Anyone noticing something I am not? I also noticed my trunk not closing like it should. If I adjust the latch any further the trunk won’t close at all, unles I slam it. By slam I mean as in both hands and holding it down.
  2. Smokey15
    Smokey15 Veteran Member
    3,412
    1,474
    Aug 13, 2017
    Caledonia, MI
    Looks to be too far back on the lid. May be the angle of the pic. Try loosening it and move forward. If it doesn't move, you may need to elongate the holes. I use thin rubber sink washers under the three pieces. Lets water escape.
  3. SRGN
    SRGN Veteran Member
    681
    241
    Feb 20, 2009
    Central NJ
    Trunk and filler panel look like they may be too far forward on the left, hard to tell from the pic. Do you have any better pics of that area?
  4. broahnazki
    259
    63
    Jan 19, 2014
    los angeles
    Here are a few shots. I will upload a few better close up pictures tomorrow BE48A6A2-D270-4E61-BB74-27C673764808.jpeg 20D18DCA-D003-48AD-9791-4596298C4A35.jpeg D92EFFA7-4E20-4EC7-9ACE-73F71AD9782E.jpeg
  5. BigBlock73
    2,179
    99
    Jul 10, 2002
    Accord,New York
    New rubber Trunk gasket ?
  6. broahnazki
    259
    63
    Jan 19, 2014
    los angeles
    Yes it’s a new one
  7. broahnazki
    259
    63
    Jan 19, 2014
    los angeles
    It’s the original sheet metal in that area but I noticed it was hit at some point
  8. badazz81z28
    20,929
    1,467
    Alabama
    Simply drilling the holes for the spoiler based on a template will give so...so results. I'm pretty sure there was a "how to" posted on here a while ago. Install the center spoiler and line up the side pieces to match it. The truck lid looks tweeked closed. But it also appears the side pieces are not lined up properly
  9. wasp
    wasp Member
    87
    10
    Mar 8, 2009
    Milpitas, CA
    Can you get a picture of the trunk looking straight down on it. use a ladder if needed to get up high enough so we can see it completely.
  10. broahnazki
    259
    63
    Jan 19, 2014
    los angeles
    1369B4F0-A1DB-427E-8B5A-E9E1A679DE9B.jpeg E02A714A-C423-410C-9D4D-DCDDFF233482.jpeg
