73 car
Discussion in '1970 - 1973 Specific' started by vernonwright, Aug 1, 2020.
  1. vernonwright
    vernonwright Veteran Member
    476
    Jan 28, 2009
    North Tazewell, VA
    WILL A 78 REAR END FIT THE 73
  2. BARNFIND
    BARNFIND Veteran Member Lifetime Gold Member
    364
    33
    Oct 20, 2007
    GPS WENT DEAD...LOST
    If you are asking about the rear differential, then yes it will fit, it is the same.
  3. vernonwright
    476
    Jan 28, 2009
    North Tazewell, VA
    thank you ......
  4. Twisted_Metal
    27,811
    1,360
    I think the only difference is a couple of drum brake pieces and possibly the U-joint design at the pinion.
    Conversion U-joints are available, if needed.
    The rear end is a direct swap at the spring perches, shocks and brake lines.
  5. vernonwright
    476
    Jan 28, 2009
    North Tazewell, VA
    thank you. that way i can just slide the hole thing in not miss with just the gears i put the hole rear housing in complete thing
  6. greeny
    greeny Veteran Member
    222
    17
    Feb 21, 2005
    arizona
    On the later models the brake line junction block is different and in a slightly different location, but will work. You should be able to transfer your brake line assemble to the newer unit if you want to make it look and connect like original.
