73 deluxe door panels
Discussion in 'Interior Restoration' started by Tricky's Zzzz, Feb 16, 2018.
  1. Tricky's Zzzz
    Tricky's Zzzz New Member
    12
    Jan 26, 2018
    I have the 73 deluxe door panels which I need to replace, and are not available unless used, and are crazy money. Can anyone tell, me what I would need to convert to the regular door panels? Thanks in advance for an help you can give me. Rick
  2. Twisted_Metal
    28,421
    1,757
    I believe the regulator shaft (where the crank fits) is longer on the deluxe doors.
    That would leave the window crank standing out away from the regular panel.
    I'm not sure if the splined area of the shaft is long enough that you could shorten it so you might want to go with standard window regulators too.
  3. xten
    xten Veteran Member
    3,796
    2,633
    Sep 24, 2014
    Pittsburgh, Pa.
    Bodymanbill's son was making the bezels on a 3D printer. The one that goes between the door panel and the window crank.That might take up some of that regulator shaft that Terry is talking about?
  4. bodymanbill
    bodymanbill Veteran Member
    1,592
    1,184
    Feb 1, 2007
    South Park Pa
    I also have a set of upper 73 Deluxe trim panels that are not perfect, the wood grain is wavy with some dings in them but the vinyl is nice ,that I would sell very reasonable also. I'm still working some of the dings out of them but should be ready to sell them in a few weeks hopefully
  5. 70lt1z28
    3,945
    870
    Oct 3, 1999
    Beavercreek, Ohio, USA
    If it is the upper part, near the window that is bad, there was a post on NastyZ where a member took the hard plastic part from a standard panel (that is available repop) and grafted onto the deluxe panel. It really turned out well.
  6. Tricky's Zzzz
    12
    Jan 26, 2018
    The vinyl on mine is where the problem is. Let me know when you are ready to sell? The lowers are in good shape.
    bodymanbill likes this.
