73 T code stock 350 upgrades for HP
Discussion in 'Tips 'n' Tricks Topic' started by EasyZ, May 28, 2021.
  1. EasyZ
    EasyZ Member Gold Member
    55
    17
    Sep 20, 2020
    Butler, PA
    Guys & Girls,
    I need some suggestions on my 1973 z28 T code 350. It is mostly stock, I have headers and HEI, that’s about it. Stock qudrajet, head’s and motor. The heads have been redone about 9 years ago (Stock set-up, lifters, valves & springs) original bottom end. This is a numbers matching Engine, I don’t want to ruin it BUT! I want a little more horse power. Any suggestions. Besides cam and aluminum heads? I’ve been thinking about pulling the T code and throwing in a BluePrint 383, just so I don’t ruin the stock 350. What would you guys and girls do?
  2. Zspoiler
    Zspoiler Veteran Member
    4,131
    492
    May 6, 2012
    Federal Way, Washington
    I would get a crate and or custom built engine and put you number matching numbers engine away .That way you can abuse the crate engine all you want, And not hurt your stock engine ,I have seen people do this a number of times .Even make the crate engine "look" stock,
    Bentley likes this.
  3. tom3
    tom3 Veteran Member
    13,794
    1,326
    Aug 1, 1999
    ohio
    Number one change in the stock engine would have to be the heads. Compression and air flow. But then the basic engine originality is shot. I too would start with a crate engine and I'd go with some setup with vortec style heads and roller cam as a minimum.
    Bentley likes this.
