74 heater hose control valve
Discussion in '1974 Specific' started by Camaro67_rcl, Jul 10, 2016.
  1. Camaro67_rcl
    Camaro67_rcl New Member
    Apr 12, 2015
    Philadelphia, Pa
    Anyone have a 74 with factory a/c ?
    Looking for location of heater control valve for a/c system. I don't see one on mine.
    Thanx
  2. ronzz572
    2,194
    116
    Feb 8, 2007
    imperial pa
    A 74 camaro with a/c does not have one. It uses a blend door internal to the interior heater box. It's vacume operated through the heater controler.
  3. Camaro67_rcl
    Apr 12, 2015
    Philadelphia, Pa
    Thank you ,,,went back out & found that out. The acutators seem to be working except one at kick panel ( no vacuum).
    Anoyone have the diagram for the vacuum lines.
    A/C is just blowing 60* air
  4. ronzz572
    2,194
    116
    Feb 8, 2007
    imperial pa
    Actually the temp door operates with the cable from the controler. It's attached behind the glove box top side of the heater box. Make sure it's moving fully. There is a adjustment at the box side of it.
  5. twozs
    twozs Veteran Member
    8,817
    169
    Aug 5, 1999
    hopewell jct ny
    silly question , how cold is the suction line ?
