74 Z28 engine rebuild time
Discussion in 'Engine Topic' started by younda, Jan 15, 2018.
  1. younda
    younda Veteran Member
    185
    59
    Jun 26, 2015
    MA USA
    I'm interested in anyone's experience with rebuilding their 74 Z28. Specifically what was done keeping stock quadrate and manifolds but open to head/cam upgrades. I am not an engine person but am being told the stock heads are not worth rebuilding and I'm not seeking maximum hp but good drivability. I'm also interested in rebuilder references in the northeast.
  2. younda
    185
    59
    Jun 26, 2015
    MA USA
    I planned on a stock rebuild but I’m told better heads and a mild cam can make big difference in power.
    Very interested in what others have done with 74’s.
  3. cadillac_al
    cadillac_al Veteran Member
    961
    122
    Apr 22, 2015
    Maine
    I have seen stock replacement heads for cheap but I can't remember where.
  4. 70lt1z28
    4,221
    967
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I have heard of "hybrid" heads that combine the best features from the LS heads into a bolt on for Gen 1's
    There are also the new Trick Flow double hump replica heads made from aluminum that are supposed to be really good. I know your car didn't have double humps originally, but it is period correct in appearance, if that matters. Paint them orange and few could tell. All depends on your budget.
  5. CorkyE
    11,257
    851
  6. Gary S
    23,811
    1,459
    That engine already has a more than mild cam in it, so depending on which aftermarket "mild cam" you choose, it could easily be a downgrade.
  7. Led Zep
    Led Zep Veteran Member
    575
    33
    Mar 13, 2008
    Ky
    Mild upgrades are always mild.You have options for a 350.They can make 200 HP or 400 HP,on pump gas.Pick the best heads for your budget,and go from there.
  8. Led Zep
    575
    33
    Mar 13, 2008
    Ky
    Rebuild the engine you have.
  9. Zspoiler
    Zspoiler Veteran Member
    3,938
    416
    May 6, 2012
    Federal Way, Washington
    You could always rebuild your stock engine with .030 over pistons.Stock crank and connecting rods machined as needed .a decent set of stock Chevy or aftermarket heads with 20.2 /1/60 valves .maybe port-matched to an Performer or Corvette intake .Something like an Corvette L-82 or aftermarket camshaft . And have your Q jet and distributor tuned to match ,
  10. Gary S
    23,811
    1,459
    The factory heads have 2.02 valves and the factory cam already in the engine is the L82 cam. For an engine like this, no changes are necessary to get a good performing car.
