74 Z28 rocker molding
Discussion in '1974 Specific' started by Jeep43, Mar 10, 2020.
  1. Jeep43
    Jeep43 Veteran Member
    1,343
    53
    Mar 30, 1999
    Connecticut
    What is correct for a 74 Z28 rocker molding. Did all Z's get the molding with the black underneath? Mines a sport coupe, not an LT.
  2. mallard
    mallard Veteran Member
    722
    165
    Oct 3, 2013
    SK, Canada
    The thin strip chrome rocker moulding with black underneath was unique to type LT. The wide chrome rocker moulding was on the non-type LT. Whether the car was a z28 or not wasn’t relevant by itself. If your VIN starts out with “1Q” then you should have the wide moulding.
  3. COPO
    18,810
    1,208
    E4417C29-B2C1-4393-9246-EB78C7B165A9.jpeg FDB3F03E-0981-4F52-890F-93DD628E0492.jpeg B7FC2A12-E8E8-446D-93D2-E47C75AFC5B5.jpeg 16E2E2FD-9457-4B0A-B14E-C6DF3E2B065F.jpeg
  4. Bigt74ltz
    Bigt74ltz New Member
    11
    Sep 29, 2016
  5. COPO
    18,810
    1,208
  6. Jeep43
    1,343
    53
    Mar 30, 1999
    Connecticut
    OK, I see the differences. The LT is 3 pieces that actually attach to the doors too. The wide just covers the rockers. That's what came with my car a single piece wide set of moldings. With the wide, there is no black paint?
    Would a Sport Coupe Z28 definitely have this trim or was it possible to get it without anything?
  7. Bigt74ltz
    11
    Sep 29, 2016
    Not sure if you could delete order the rocker moldings. I always liked the black paint on the bottom, the car appears smaller.
  8. BillyDean7173
    BillyDean7173 Veteran Member
    2,018
    549
    May 21, 2014
    Hutto, TX
    No black paint. Should be body color.
    It would definitely have the wide rocker panel molding. It was not an option. There were retaining strips, clips, screws, and Nelson studs holding the trim on there, so you just couldn't remove the trim without taking off the retaining strips, grinding/removing the studs, filling in holes, and then repainting.
  9. COPO
    18,810
    1,208
    The rocker trim on non LT’s is the same as 70-73 Z28’s.
    F84D5845-55D7-4D1D-9070-9A65D7CF41B3.jpeg A9C2A243-6A6D-4DA0-9405-A286C7E2CE07.jpeg 7DCE4015-8E02-4EE2-B9AD-5F44B6A34DFD.jpeg
    BillyDean7173 likes this.
  10. 74Z28GC3
    74Z28GC3 Veteran Member
    1,749
    65
    Sep 1, 2000
    North Pole, Alaska
    Clip number is 4510031. There are 6 clips per side.
