thesalboy
He's coilovers all around, I think, and yes to just roll it around something solid is fine.
the front subframe will be modified for better coil over mounts
Here is the install video of what I'm doing, at one point he uses a plasma cutter to allow more room for the shock, is this what you're describing? (skip to 4:15 if you don't want to watch the entire video)I had to grind metal away where the coil spring passes through the mount's lower hoop
huge pita
yup, was pretty neat, was a 1970 with 62000 original miles, car looked greatpretty sweet Trans Am's tho!
