There is a seal around the gear selector shaft on the driver’s side.
I think you may need a special tool to replace it if you find the leak there.
I'm pretty sure that's it. Napa kit for 9 bucks and a little work. Thanks Twisted!There is a seal around the gear selector shaft on the driver’s side.
Thank You sirThe drain plugs are normally sealed with seam sealer from the factory.
There should be no problem covering them with sound deadener.
