Well, today I received the brand new printed circuit. The other day I received the led bulbs that @Twisted_Metal had suggested in another thread. Temporarily hooked up the cluster today. Also flipped that dome light switch plug for the led dome light. Now have a dome light. A very bright one.
STILL NO GAUGE LIGHTS:
I still (as I said in the other thread) do not have any other gauge lights. Aren't some of the gauge lights just ambient light controlled by the headlight switch and or door?
My bright light indicator works (Blue indicator light), my turn signals work (Bottom green lights) but I see no ambient lights at all. Not good for night driving lol. What else could I be missing here?
The lights under the column didn't turn on either. (Heater control, etc. Might be of note that I have not hooked back the heater controls or cig lighter plug back to the stitches and housing yet. Not sure if they are part of a circuit for the ambient lights or necessary for them to work.
DOME LIGHT DOOR SWITCH ISSUE:
Unfortunately for whatever reason, the driver's door doesn't activate the door shut off switch for the dome so I had to unhook the battery for now. It's weird, this is the original door, but the switch just misses the metal when you close the door. I will have to find a solution for this. Has anyone see this before on their and how did you correct it?
I did repair the tabs on the cluster housing thanks to the tutorial on this site as well. Although I passed on using the metal foil over them as I dont believe that lends much support.
Overall I'm happy I have some lights.
