77 Type LT Budget Build
Discussion in 'Project Progress' started by ZerroHalfcup, Apr 3, 2019.
  1. Gasoholic
    Gasoholic Veteran Member
    198
    82
    Apr 2, 2019
    MI
    Good to see you chipping away.
    ZerroHalfcup likes this.
  2. 76 for 26
    76 for 26 Member
    56
    22
    Dec 29, 2015
    NC
    I’m currently installing a full floor pan with braces and torque boxes I purchased from npd. It was pretty decent. So far, Torque boxes were off ever so slightly and I had to make several relief cuts to eliminate gaps on both ends, but nothing big. Couple pics over on my thread...currently working on attaching the sides to the rockers.
  3. ZerroHalfcup
    ZerroHalfcup Member
    42
    19
    Apr 2, 2019
    Memphis, TN
    I just read through your thread, I have a lot of respect for you man. I love your reason for wanting to do it and it looks like you have made some awesome progress. Thankfully my torque boxes, frame rails and floor braces, with the exception of one that is a little tweaked, are pretty solid. My car seems to have lived in the south it's entire life so all of the rot came from where piles of leaves and dirt sat in it while it was sitting out in a field. Best of luck with your car, I'm definitely going to have to keep up with your progress.
  4. ZerroHalfcup
    ZerroHalfcup Member
    42
    19
    Apr 2, 2019
    Memphis, TN
    Still need to tweak the fitment in the top right and along the trans tunnel but everywhere else I'm happy with. It won't be perfect but I'm shooting for function over form here so as long as it's solid and holds, then rock n roll. I was hoping to have this welded in weeks ago but it's crazy how much things change in a short time. Hoping to get some tac welds on it tonight and work on getting the fitment closer but I'm not holding my breath. Fingers crossed
    [email protected] likes this.
  5. RS1979
    4,055
    966
    Jun 18, 2013
    Memphis, TN
    With school being on hold, you'll have some extra time.
  6. Gasoholic
    198
    82
    Apr 2, 2019
    MI
    Looks good.
    Keep us posted
  7. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,633
    1,058
    Mar 27, 2016
    NY
    I might have some parts for your car, I think, a tail light or two, a part of the grill and maybe rear window trim, and I actually have the rear glass, however that would be a bioch to shipp haa ha, any ways, I will not need them I got them from a guy cheap with some parts I needed , so I would let you have them cheaap
  8. ZerroHalfcup
    ZerroHalfcup Member
    42
    19
    Apr 2, 2019
    Memphis, TN
    That's the funny part. I'm very lucky to have the ability to work from home so between classes being online now and work, I'm still just as busy. The only difference is the car is downstairs and I can't really touch it throughout the day.
    I may get with you on those taillights and grille. The car came with the rear glass, I just pulled it out and moved it inside along with some other parts.
  9. Zspoiler
    Zspoiler Veteran Member
    3,986
    438
    May 6, 2012
    Federal Way, Washington
    well you just do it as you can .Remember its a hobby.
  10. ZerroHalfcup
    ZerroHalfcup Member
    42
    19
    Apr 2, 2019
    Memphis, TN
    Every other time I touch this car, I learn something new. This is round two of doing plug welds, turns out they aren't much good if they don't penetrate the metal behind it. Gave it a few good yanks at different points and these are holding nice and tight. Still need to finish welding the rest of it in along the trans tunnel but I'm going to have to make a piece to fill that gap. I'm not really in the mood to create a 3/8" wide weld.
    Gasoholic likes this.
