78 Camaro Type PT
Discussion in 'Project Progress' started by 70rsss, Jan 2, 2018.
  1. 70rsss
    70rsss Veteran Member Lifetime Gold Member
    374
    Mar 29, 2000
    Houston, TX.
    Had a buddy come by and help me move the sub-frame from my rear porch to the garage. Well with all the time I had off work during the holidays I was able get a project back on track. There is a since of accomplishment when you get your sub-frame assembled for the last time. A lot of work and some engineering has got me to this point……As I stated before I didn’t want to go with the non-adjustable sway bar that came with the SpeedTech front suspension so with their help sway bar rates I converted to an adjustable torsion bar set up. This is common on aftermarket sub-frame with rack & pinion but is a PITA setting up with a factory sub-frame and steering box. Because the tube, the bar rides in,has to be welded to the front of the steering box the steering arms operate between the lower control are and the sway bar linkage.
    25395777_10208299652608304_38330634041170987_n.jpg 25660127_10208343592146765_3681123916304079207_n.jpg 26001402_10208337342910538_2029971281556582718_n.jpg
    Before I installed the JRI shocks I did a quick bump steer adjustment just to get into the pall bark. I will lock in the bump steer after car is built and has a real alignment.
    26166124_10208353757400890_2582137198200898646_n.jpg 26165454_10208365493574287_591578222320560434_n.jpg
  2. 70rsss
    374
    Mar 29, 2000
    Houston, TX.
    The last part of my holiday progress was to get my car back on 4 wheels, even if the front wheels are the same diameter as the rotors I will be running….lol With the help of my bike lift and a floor jack I maneuvered the sub-frame till I got the middle solid bushings aligned and bolts almost fully tightened, I was then able to lift the car and do the rears. Back down and the sub-frame back on the bike lift I was able to push the car back putting all wheel back on the lift.
    26047007_10208359800791971_1755805523503052215_n.jpg 26047423_10208359800871973_3450473151730099763_n.jpg 26113985_10208365493614288_3584464896473657081_n.jpg
    To top off New Year’s day I installed the motor/trans fully completing the goals I set for myself for my X-Mas & N.Y vacation.
    26165473_10208383429182666_7769173607782515424_n.jpg 26112232_10208383429142665_7871867976974190506_n.jpg
  3. 70rsss
    374
    Mar 29, 2000
    Houston, TX.
    Well from the last update I’ve done a bunch of work with little progress. Lost a week thanks to Jegs sending me the wrong flexplate kit to go between my LQ9 & 700r4. Once I got the tranny bolted up I found I had a clearance problem between the left rear coil pack and one of the humps over the tranny tunnel on the firewall. All I needed to do is slide the motor forward ½” but the tranny mount was already at the end of the slot on the tranny X-member. So I had to pull out the X-member and have the mounting plate stretched forward 1”.
    After I got X-member back and reinstalled and the motor bolted into the final location I dropped the intake on the motor to have a look how the air cleaner fitment. Looks like it’s going to work like a champ…..yea! Won’t bolt it on for good till I get all the wiring done.
    26229449_10208448361885943_2848217248051698294_n.jpg 26230003_10208448361925944_7412889606583700616_n.jpg
    Next I bolted up the master cylinder but to my dismay the mounting brackets have it pointing up at a steep angle and will need to be modified……always something! Lol
  4. 70rsss
    374
    Mar 29, 2000
    Houston, TX.
    Over the last couple of weekends I have cut down my booster bracket to reduce the angle of the master cylinder and played with the brake pedal. Waiting on a new Clayton Machine brake pad and throttle to install everything. Had a bung welded on my new aluminum tranny pan for a temp sensor for my digital dash. But the real progress came when I removed the axle and rear suspension. Now I can clean the bottom back half this weekend and weld in the upper shock mounting bar for the SpeedTech torque arm setup. Once that is done I can mock up my 9” and locate and weld the final brackets for the sway bar before powder coating. After Detroit Speed inner fenders and sub-frame connectors I can bed-coat to match the front.
    27336887_10208587661448345_3954921725177216792_n.jpg 27750687_10208587661528347_6697164991042188468_n.jpg 27459436_10208587661488346_3123258825825776538_n.jpg 27459108_10208587661568348_580080957812418175_n.jpg
  5. 70rsss
    374
    Mar 29, 2000
    Houston, TX.
    Well it was a productive three day weekend for me. Spent a Friday scrubbing the back side of the undercarriage with multiple cleaners and brushes (nasty Job!) so it is nice and clean now. Saturday morning I hit the bottom again but with a bucket of soapy water and a scotch bright pad.
    Since my cool looking Clayton Machine Works brake pad and throttle came in I was able to reinstall the brake pedal assembly. This in turn allowed me to bolt up the booster and master cylinder with the modified brackets I had cut down to reduce the angle of the MC.
    Sunday morning I had my buddy Randy Porter come over and burn in my SpeedTech shock mount crossmember. While I have my own welded and do weld I leave the critical welding to a professional especially since he makes house calls! LOL After Randy made short work on the X member I was able to mock up the rear end and get the sway bar mounts in place where I can weld them in this week.
    28058488_10208628468508496_8827098821058820171_n.jpg 28056170_10208628468628499_5803927597183115637_n.jpg 27868045_10208628469708526_7442140255019284594_n.jpg 27657717_10208628469668525_1673911662232413704_n.jpg 27657406_10208628469748527_7798094870895299918_n.jpg
