79 Camaro Z28 rear wheel fitment?? Will these fit?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Dans79, May 14, 2017.
  1. Dans79
    Dans79 Member
    34
    May 8, 2017
    Will this size tire fit a stock rear end, without having to roll the rear fenders.
    15x8 rims on P275/60R15 Rear Tires
  2. Zspoiler
    Zspoiler Veteran Member
    3,499
    290
    May 6, 2012
    Federal Way, Washington
    They should fit easily as long as the offset is correct,
  3. Dans79
    Dans79 Member
    34
    May 8, 2017
    Would you say 4-4.5 bs is the way to go?
    Thanks in advance.
    Dan
  4. Zspoiler
    3,499
    290
    May 6, 2012
    I run 17 x 8 Torque Thrust II s .With 4 inch back spacing in front and 5 inches of back spacing .Check at Tire Rack.Com to check for sure. 130044932860518017_26257430996_o (1).jpg
  5. Dans79
    Dans79 Member
    34
    May 8, 2017
    Beautiful car! What front end is that?
  6. Zspoiler
    3,499
    290
    May 6, 2012
    That is an Fibremotive IMSA Camel GT front nose. It was part of a kit of the nose huge flares and a wing. Similar to the one picture attached ..I was going to make my own version of the IMSA Camaro. But they went out of business when i saved up the money. So I built it the way pictured ,with all sorts of "toys" underneath Some are no longer in prodution 5529277575_d2325a91e8_b_26512224230_o.jpg ,And it would br scary to add the recites up.So I won`t
  7. 78Z28rocker
    78Z28rocker Member
    34
    May 8, 2006
    Auburn,AL
    Probably 4.5 is the way to go. I'm running a 18x9 with a 5" backspacing and a 275/40/18. I could probably have gone with a little more backspacing but the rim cost increased dramatically. I did have to trim a little sheet metal from the wheel lip, approximately 1/8" inch from my left side only.
  8. Dans79
    Dans79 Member
    34
    May 8, 2017
    Thanks guys
