79 clutch fork return spring ?
Discussion in 'Transmission & Driveline Topics' started by DW Holeshot, Nov 19, 2012.
  1. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    what you can do is. Run one spring from the fork to the hole beside the adjustment rod. This keeps the rod from falling out. then put another spring to hold the fork/peddle up. I put my second spring on the inside under the dash. Work great so far. I know its not stock. But it doesnt interfere with my headers this way.
  2. DW Holeshot
    DW Holeshot Member
    58
    May 2, 2012
    Yerington Nevada
    Thanks Hoot
    I think I have it covered being the new stock replacement spring to the frame is plenty stout. Sorry the photos went away, I moved them to another spot in my photo bucket and I guess it did not like that.
    Dale :bowtie:
  3. BigBlock73
    2,188
    107
    Jul 10, 2002
    Accord,New York
    My spring is hitting the headers and making noise when the pedal is depressed.
    I plan on welding a nut to the frame, were there will be no interference, and use an eye-bolt to attache the spring.
