79 z28 blower motor relay clicks but no blower
Discussion in '1978 - 1981 Specific' started by Mrwalleyeman, Mar 17, 2020.
  1. Mrwalleyeman
    Mrwalleyeman New Member
    13
    Feb 26, 2020
    So I have been trying the last few days to get the heater working on my sons camaro. so far I have tested and have power at the switch and power to the relay and power to the brown wire going to the blower motor, haven't gotten to the blower motor yet. But when you flip the switch on the dash you can hear the relay clicking. So I don't know if that is normal or not. I think we need to replace the blower motor. Any ideas would be helpful. Thanks
  2. Gary S
    23,517
    1,325
    The relay should activate when you switch to high speed. When that happens, you get power out of the line from the relay to the motor. If it gets out of the relay and not to the motor, trace the wire. Most GM cars had an inline plug between those two places. This plug wasn't heavy enough to handle the current of the motor for the long term and can burn up.
  3. Mrwalleyeman
    13
    Feb 26, 2020
    Thanks Gary S for the reply.
    I will dig into it more tomorrow and report back.
  4. Twisted_Metal
    28,457
    1,778
    Check for power at the wire to the blower.
    If you have power there, it's a bad fan motor.
  5. mallard
    mallard Veteran Member
    930
    246
    Oct 3, 2013
    SK, Canada
    Quite likely the heater motor is shot, IMHO.
  6. budro6968
    budro6968 Veteran Member
    3,728
    688
    Apr 2, 2016
    Jax Florida
    When you see someone driving their 2nd gen Camaro with the window cracked open in the rain. You know their Blower is toast They are so much fun to replace.
  7. Jim Streib
    404
    67
    Apr 6, 2004
    Saint Louis, MO USA
    On cars with AC, the blower motor is mounted to a plastic non-conductive housing and thus requires the blower motor to have a ground wire off of it or one of it's attaching bolts. You can have all the power in the world going to a perfectly fine blower motor but if it's not grounded it will not work.
    It could be a ground connection and not even a power delivery issue.
    The cars that have the metal engine side heater covers that the blower mounted to normally did not have a dedicated ground as the motor self grounded to the metal housing and then the metal housing grounded to the firewall.
    Jim
  8. Zspoiler
    Zspoiler Veteran Member
    3,779
    365
    May 6, 2012
    Federal Way, Washington
    You should trace your wiring for any issues .You can run a bypass and see if the motor itself is defective as well.
  9. Twisted_Metal
    28,457
    1,778
    Good Point, Jim!
    Getting to those ground connections requires you to remove the front passenger wheel and most of the bolts for the inner fender well so you can lower it to gain access to the blower motor behind it.
    If you need to replace the blower motor.... you've got the hard part done.
    Note: A/C and non-A/C cars have a squirrel cage on the motor which is the same diameter but different in depth.
  10. Mrwalleyeman
    13
    Feb 26, 2020
    Thanks everyone for the info. Looks like my son and I are going to be working on it this weekend.
