79 Z28 casting numbers
Discussion in '1978 - 1981 Specific' started by Kylejohn695, Dec 9, 2020.
  1. COPO
    20,077
    1,997
    3890462....1966-67
    2ndOwner78 likes this.
  2. Chevyforever
    Chevyforever Veteran Member
    984
    285
    Jan 4, 2011
    DRF 79 Camaro 170hp block
  3. Camaromurph
    Camaromurph Veteran Member
    232
    92
    Oct 20, 2018
    Naperville, IL
    DRF is okay for 79 350 with manual trans according to this site. There should be a partial vin stamped in the same place that will tell you if it is original to the car.
  4. Kylejohn695
    Kylejohn695 New Member
    10
    Dec 9, 2020
    Thanks for all the info guys I really appreciate the help!
  5. 2ndOwner78
    2ndOwner78 Member
    91
    41
    Nov 6, 2014
    Minneapolis, MN
    So with that it looks like you may have the block that came in the car from the factory (need to find the VIN stamp on the block to confirm that) that has had better heads installed at some point.
    This info came right from the NastyZ28 engine code info. Flint, MI built engine on October 25th.
    - DRF = 1979 350 auto trans. L LM1 170 4 Camaro
  6. 79ZED
    79ZED Veteran Member
    3,099
    11
    Jan 31, 2000
    Nanaimo, B.C., Canada
    DRF was also used behind ST-10 manual trans '79 Z28's and perhaps others.
  7. Kylejohn695
    10
    Dec 9, 2020
    I just ripped the Borg-Warner super t 10 (with the three cross hatch lines on the input shaft) out of mine the brass bushing was installed incorrectly and was making some horrendous noise.
  8. Kylejohn695
    10
    Dec 9, 2020
    When you’re referring to the “L LM1” what does that refer to?
  9. 2ndOwner78
    2ndOwner78 Member
    91
    41
    Nov 6, 2014
    Minneapolis, MN
  10. COPO
    20,077
    1,997
    LM1 was the designation for the 350.
