79 Z28.. What to look for?
Discussion in '1978 - 1981 Specific' started by Danalanah, Apr 28, 2020.
  1. Danalanah
    Danalanah New Member
    Apr 27, 2020
    Going tomorrow morning to check out a 1979 Camaro Z28. What are some things I should keep an eye out for or be sure to inspect? Any questions I should be sure to ask? It is going to be a project. Thanks.
  2. Zspoiler
    Zspoiler Veteran Member
    3,533
    299
    May 6, 2012
    Federal Way, Washington
    Its a Fisher Body rust can always an issue .Especially a "T" top car .The condition of the car overall .And is it safe to driver
  3. flht99b
    flht99b Veteran Member Gold Member
    567
    163
    Nov 28, 2014
    Knoxville, TN
    Assuming rust and the necessary metal repair is the most time consuming, difficult and expensive work:
    Thoroughly inspect the floors, trunk, inner and outer wheel housing, bottom of fenders, doors and quarters and cowl area. Look for previous collision damage. Take a magnet with you and if possible someone familiar with or better yet an enthusiast of the 2nd Camaro.
  4. BillyDean7173
    BillyDean7173 Veteran Member
    2,100
    603
    May 21, 2014
    Hutto, TX
    Frame rails at the back of the car on the outside of the gas tank. Rocker panels below the door (inside and outside). Check for partial VIN on the motor and tranny and make sure it matches dash. Check trim tag on cowl. Ask for build sheet and other documentation.
  5. COPO
    18,896
    1,245
    Walk if it’s a T top, just my opinion.
    flht99b likes this.
