79 Z28 won't idle and sounds rough
Discussion in 'Troubleshooting & Diagnosis' started by Andy Jones, Nov 21, 2020.
  1. Andy Jones
    Andy Jones Veteran Member
    113
    Jan 11, 2020
    Hi
    Have a 79 Z28. Rebuilt the carbs (Rochester qjet) a few weeks back and the car ran great. My son drove it here and there for a few weeks and then to college (120 miles), also great. Half way home it died. Now I can start it but it won't idle. You can keep it running on the throttle but sounds like a cylinder is missing and you can smell gas like it's running rich.
    Have just changed all the vacuum lines but no difference.
    Any help appreciated. Am at a loss.
    Andy
  2. zekefreak
    zekefreak Veteran Member Lifetime Gold Member
    1,560
    42
    Apr 16, 2006
    western PA
    Could be a bunch of things but my first guess is its electrical. Pull all the plugs. They should be a tan color but if one or more are black then I would check those cylinders first. check compression and the condition of the wires or distributor cap. If the plugs are all black/sooty then it could be the distributor or timing chain. Then again, it could be the carb. Start with the basics.
  3. Andy Jones
    113
    Jan 11, 2020
    Thanks
    I pulled 2 plugs and they looked good. All plugs and wires are new
    I will check the rest and do a compression check. Was hoping to avoid this as the back 2 on the passenger side are terrible to get to. But needs must.
    Also checked fuel inlet. Pump seems to be working fine
  4. zekefreak
    1,560
    42
    Apr 16, 2006
    western PA
    check the distributor cap for cracks.
  5. Andy Jones
    113
    Jan 11, 2020
    It's new also but will check.
    It feels to me like a fuel issue but don't see how.
  6. Zspoiler
    Zspoiler Veteran Member
    3,779
    366
    May 6, 2012
    Federal Way, Washington
    Check for vacuum leaks as well
  7. Andy Jones
    113
    Jan 11, 2020
    Thanks
    Changed all the vacuum hoses
    I'm thinking it could be the float.
    Thoughts?
  8. berg2695
    berg2695 Veteran Member
    384
    94
    Nov 13, 2011
    AUBURN, WA
    I think you are on the right track. Gonna have to take the top off the Q-Jet.
  9. Andy Jones
    113
    Jan 11, 2020
    Yeah. If it fixes it, it will be worth it...
    Will let you know tomorrow if it works.
  10. zekefreak
    1,560
    42
    Apr 16, 2006
    western PA
    Did you adjust the timing and possibly not tighten the hold down bolt and the distributor moved? I'm just wondering how something could change so quickly.
    berg2695 likes this.
