8.5 inch posi
Discussion in 'Transmission & Driveline Topics' started by AJ81Z28, Mar 12, 2018.
  1. AJ81Z28
    AJ81Z28 Member
    49
    Mar 21, 2017
    Can the carriers be rebuilt? Not the whole thing. Just the Posi. I'm getting conflicting information. It is the original posi unit in an 81 Z28.
    It's not lighting up both tires anymore. Just the right side tire. That's why I'm asking.
  2. big gear head
    big gear head Veteran Member
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    Depends on which one it is. If it's the Traction Lock then Tory makes new clutches and shims for it. If it's an Auburn then it's scrap metal.
  3. AJ81Z28
    AJ81Z28 Member
    49
    Mar 21, 2017
    Is there a way to tell the difference?
  4. Zspoiler
    Zspoiler Veteran Member
    3,934
    415
    May 6, 2012
    Federal Way, Washington
    If all else fails take to a local shop.
  5. big gear head
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    You have to remove the cover and look at it.
  6. 74BIBELOT
    74BIBELOT Veteran Member
    865
    57
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    F7026A42-4725-4A76-916D-011A295F9FB0.png A36C8C3D-00B5-424A-90F4-B3E4B7CD56EB.png This is a “rebuildable” posi:
