81 Camaro 4 speed swap
Discussion in 'Transmission & Driveline Topics' started by 04silvyhotrod, May 14, 2014.
  1. Ghostof76
    Ghostof76 Veteran Member
    424
    Feb 25, 2012
    Devonshire N.Wilmington,De. Hot Rods to Hell (East
    327, s like to wind out quick. The trans with it's 2.20 first gear and 3.73 rear your planning may not be enough . Your start line ratio will only be 8.20. 2.20 X 3.73 = 8.20 . You'll be better off with 4.10's despite sucking on the highway. 2.20 X 4.10 = 9.02 start ratio. Much better for that motor.
  2. black_aerocoupe
    552
    30
    Jun 3, 2008
    McD's @ the Pavillions, AZ
    No. Get a 5 or 6 speed.
  3. Camaro-Chevelle
    Camaro-Chevelle Veteran Member Lifetime Gold Member
    227
    Sep 22, 2007
    Long Island, New York
    When installing steep gears, it is always best to install an overdrive transmission. This will give you the best of everything. You will have great off the line power without sacrificing a comfortable RPM on the highway. A good compromise for now would be to purchase the M21 from your friend. Sell it and find a M20 that will work with your 3.08 rear differential. Save your money and invest it into a Tremec and a rebuild of the rear differential with 4.10s. I know it sounds like a lot of money, but it will be worth it in the long run.
  4. 04silvyhotrod
    04silvyhotrod Veteran Member
    213
    Apr 12, 2014
    Tennessee
    I was thinking about selling the m21 and buying a M20. But the borg warner st-10 has a lower first gear than the m20. I also know where one of them is at. I drive the car right now with the auto but I never did like a auto in a car. The th-350 needs freshened up and would rather put the money on a 4 speed swap.
  5. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    I run a ST-10 with a 2.73 gear, turns just nice going down the highway. Has stood up to its fair share of nitrous hits as well, no issues.
  6. Jonzz28
    Jonzz28 Member
    51
    Sep 2, 2013
    Northern VA
    My M21 + LT1 + 3.73 = FUN. I can smoke them off the line with ease, it never bogs, never chatters, and can cruise without it being insane. Now I have an upgraded Ram clutch, so that helps, but it has not left me wanting 4.10's. Not yet anyway. ;)
  7. 04silvyhotrod
    213
    Apr 12, 2014
    Tennessee
    I've been talking to the man with the st-10 and will be getting it instead of the m21. That way I can run the 3.08 gears out the back.
  8. Hey G
    Hey G Veteran Member
    519
    Mar 18, 2012
    SC
    At Jonzz28, what kind of RPMs do your run @ 65-70 mph on the highway? I have the same combo going in my car...someday.
    G
  9. Jonzz28
    Jonzz28 Member
    51
    Sep 2, 2013
    Northern VA
    At @ 3200 -3400 at 65-70mph.
  10. DoTheDew
    899
    Mar 2, 2010
    Leduc, Alberta
    Most (not all) of the st-10's came with a low ratio first gear for low speed rear end's like the 3.08, they were designed to work together. Technically the weakest of the bunch due to that low first gear, but I've left hard many a time producing in excess of 300 hp on the juice, and never had an issue.
    Having the low first makes it great in traffic, and the spread between the gears is about perfect.
