81 hood springs for 2" cowl hood (steel)
Discussion in 'Body Restoration' started by arnies81camaro, Nov 2, 2012.
  1. arnies81camaro
    arnies81camaro Member
    59
    Aug 20, 2011
    groveland,ma.
    I just picked up a 2" Goodmark cowl hood! I'm looking for a set of hood springs to hold it up. I have a 4" cowl bolt on fiberglass hood,those spring won't hold up the steel hood. I will be selling the 4" hood after I get the 2" cowl hood painted!:bowtie:
  2. doublec
    doublec Veteran Member
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    I had the exact same scenario. The car I purchased had a 4" fiberglass, bought a 2" steel cowl Goodmark and the springs would not hold it up. I purchased springs right through Goodmark and they work like a champ.
  3. B.M.
    B.M. Veteran Member
    903
    Jan 11, 2010
    Columbus,Ohio
    Just about any place that sells camaro parts should sell factory replacement springs,and those should work fine.
