81 master cyliner
Pete77LT
220
Hacienda Heights, CA
81 master cylinder
Did a search and really couldn't find a definitive answer. Can I use the ligher master cylinder off of an 81 in my 77 and will the brakes function properly? Mine needs replacing and was looking for another option. Thanx
3SLO5
3,639
Edison NJ USA
if you get the matching booster with it it will work, the circufrance at the rear wont fit in the earlier booster unless you get it turned down.
JONESYFXR
2,177
BUFFALO, NY
I Took A Booster/ Master Cylinder From An 87 Monte And Fit It Into My Friend's 72 Chevelle. We Had To Use The Factory Bracket And Fab A Brake Rod. The Booster Has Double Diaghrams And Is Smaller In Diameter Than His Stock One. He Says The Brakes Are Better Than They've Ever Been, Plus It Is A Plastic Resevior Like From A Third Gen Camaro.
Good Luck!!!
