'81 Z28 Project Overboard
Discussion in 'Project Progress' started by Wally's World, Aug 24, 2021.
  1. Wally's World
    Wally's World New Member
    Apr 16, 2020
    Finally found a 1981 Z28 that I can afford.
    Ratty_81 likes this.
  2. 80sz
    80sz Veteran Member
    3,928
    748
    Feb 2, 2014
    Buffalo,n.y.
    nice story
  3. Ratty_81
    Ratty_81 Veteran Member
    215
    119
    Nov 13, 2020
  4. 80sz
    80sz Veteran Member
    3,928
    748
    Feb 2, 2014
    Buffalo,n.y.
    the silvers pretry rare, i like it with opal dash color
  5. berg2695
    berg2695 Veteran Member
    567
    213
    Nov 13, 2011
    AUBURN, WA
    I like your sense of humor and writing style. Keep the posts coming!
    80sz likes this.
  6. mrfleet12
    mrfleet12 Veteran Member
    953
    593
    Aug 8, 2014
    West of Chicago IL
    I'm a fan of that silver for sure..
    With the 05 GTO 4L65E I had in my 73, I ran both 3.73 and 3.42... Not much difference between the 2, the .73 was a little more fun around town and the .42 slightly better on the road... I'm planning the build for my next one, I'll be going .73 in my 70.
  7. mrfleet12
    953
    593
    Aug 8, 2014
    West of Chicago IL
    Have you set the 05 GTO engine in place yet, curious if the front accessory stuff works for you and if yes, what mounts are you using.
    Mine hit the steering gear box, I ended up using Vette accessories.
  8. SPG
    SPG Bumblebee Builder
    1,140
    426
    Sep 1, 2018
    Sacramento
    If it makes you feel any better about it, DSE subframe connectors are the best on the market in terms of function.
    If you're not too thrilled about cutting up your floor, weld in connectors from global west work pretty well too.
    mrfleet12 likes this.
  9. Ratty_81
    215
    119
    Nov 13, 2020
    6573C657-085C-4D69-AF8E-0349083B2563.jpeg FD56618E-0C4B-4A1F-B8BF-8D6B9055B386.jpeg
    Or since you’ve got full access to the torque boxes, just make your own from 2x3 11ga tubing.
  10. 92Camarors
    92Camarors New Member
    9
    Oct 25, 2020
    Different generation, but I just rebuilt my rear and replaced the open carrier with a Eaton style LSD and 3.73 gears. I love it. Trying to get used to the difference in rpm at certain speeds, but that's only because I have driven this car for 20 years with the same setup. With the stock setup 3rd gear sucked! I would have to hold 2nd until close to the redline. Even then you could still feel the lack of torque until about half way through 3rd gear. With 3.73 gears 3rd pulls just as nicely as the other gears. It realy brought consistency to all 5 gears. Even pulls nicely if I'm cruising in 5th, and give her a goose to pass a slow poke in the left lane without needing to down shift. Realy worth the slightly higher rpms, and little less mpg in my opinion. As it realy improved the acceleration behavior overall.
