losboricua
So, my dad came up for thanksgiving and he was able to help me finally get started to remove the front end. The car has been in the family since I was 5 yo(now 37). Right before I had the car shipped from PR to the states, the car was hit on the driver’s side front and bent the subframe. He was able to put the car together and I was able to ship it to up about 7 years ago. Finally, I found a used and good-condition subframe (straight and not rusted) about two years ago.
After we took the front clip out we found a little more rust damage on both side panels of the firewall and a little area under the AC box. Then I found the passenger-side subframe body rails snapped some welds during the car accident. So now the full restoration project that I wanted to do when my kids got older will start early.
Plan:
One question, for the replacement body panels which manufacturer fits closer to OEM. OER, Dynacorn, etc?
Wreck
Repaired
Now getting dismantled
Plan:
- Front area rust repair and some small trunk rust repair. The rest of the car is pretty rust-free since it is a PR car.
- Firewall smoothing
- Vintage air AC/Heating
- New dash, the current one cracked because of heat, and the cover did not work well
- Repaint factory color
- Frame connector Globalwest(already got) with solid mounts
- The current SBC350 is in great condition, along with the TH400
- I refreshed the rear last year with disk brakes, so I will be reusing it
- Front suspension will most likely do a UMI front kit with a quick steer gearbox
- Upgrade to the Intake manifold with multiport EFI
- C5/C7 front brake upgrade
- N90 17” clone factory wheels
Wreck
Repaired
