88 IROC - Whiny Rear-End while coasting, goes away when accelerating
Discussion in 'Transmission & Driveline Topics' started by mgd1790, Sep 1, 2020.
  1. GoldenOne7710
    5,612
    894
    Jun 23, 2004
    Athens, GA
    It probably IS bad at this point. I would go ahead and pull the yoke and change the seal while you're there...then reinstall the yoke and tighten the nut to the specs BGH posted. Remember to top off the gear oil...most of yours was on the exhaust pipe and torque arm.
    Oh yeah...might want to kill the spider.
    [email protected] likes this.
  2. ronzz572
    2,417
    232
    Feb 8, 2007
    imperial pa
    Mike judging by what I saw in the video the pinion yoke doesn't even look correct. And,, Also someone actually used a bolt with a hex nut on the u joint strap. Even if tightening the pinion nut fixes the rear. That pinion yoke is going to rattle your teeth from vibration at 60 mph. It will need replaced.
  3. 76z28
    76z28 Veteran Member
    2,392
    183
    Jun 29, 2009
    bakersfield
    I just started having this issue on Sunday on my way home from 100 mile drive.... Really hoping it's a loose pinion nut.... Otherwise I'll be going to a 9 inch with 4.30 gears
    John Wright likes this.
  4. Knuckle Dragger
    16,566
    2,892
    Nov 2, 2002
    Waddell AZ
    Kind of a waste of time and money to change the seal until you know if the bearings are good, IMO
    big gear head likes this.
  5. John Wright
    15,258
    418
    Aug 9, 2002
    Rustburg, Va
    BGH said it...the seal just keeps the oil in and the dirt out. You have something more than just a seal going on. Take the drive shaft off the pinion yoke and try tightening that pinion nut. That won't cost anything to try.
  6. dkcamaro
    dkcamaro Veteran Member Lifetime Gold Member
    197
    Dec 19, 2009
    HARTSDALE, NEW YORK 10530
    Looks like someone beat the hell out of the yoke with a BFH. Probably to change the seal that is hanging out of the housing. Oil should be pouring out? Looks kind of dry?
    I like what looks like a regular nut and bolt holding the strap on
  7. big gear head
    big gear head Veteran Member
    6,443
    185
    Jul 30, 2001
    Ky.
    I've seen people put a rear end together with a new crush spacer and not go through the procedure of crushing it. They thought that when the nut got tight it was good enough. This could be the case here.
  8. 76z28
    2,392
    183
    Jun 29, 2009
    bakersfield
    I wish that were my freaking case, mine was set at 18inch pounds and after about 8,000 miles just started. I am hopeful a bearing isn't going out as it is only on decel, but we will see saturday!
  9. Lowend
    16,541
    1,301
    Mar 25, 1999
    San Jose, CA, USA
    Those 7.5" 10-bolts are notoriously weak. it was originally designed for the 6-Cylinder Vega, which had a whole 120 ft/lbs of torque.
    I can't keep track of how many of those things I saw destroyed in 4th gens
  10. big gear head
    6,443
    185
    Jul 30, 2001
    Ky.
    I took a look at that video again. The yoke needs to be replaced if you intend to keep this. Someone has been done some damage to that thing.
