94 versus 97 LT1 differences
Discussion in 'Engine Topic' started by mgd1790, Jun 16, 2021.
  1. mgd1790
    mgd1790 Veteran Member
    1,051
    29
    Nov 25, 2003
    Suburban Chicago
    Hi,
    My 97 Z28 has a bad motor and I've seen LT1s from different years posted online. One of the motors I was looking at was a 94. Does the 94 LT1 work for a 97 Z28?
  2. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    191
    26
    Oct 4, 2002
    Buffalo,NY,USA
    Yes but your '97 timing chain cover needs to be swapped to the 94 a maybe some sensors.
  3. sooner
    sooner Veteran Member Lifetime Gold Member
    1,567
    104
    Mar 11, 2009
    Perry,Ok
    The 94 will have a vented opti and as posted above the timing cover will need to be changed to your 97 to accommodate the crank sensor as the early LT1's were a batch fire rig. I assume that you are going to use your late model non vented opti off of your 97. Just use the 97 harness on it. As above there may be some sensors to change out considering that it went from obd1 to obd2 for the 1996-1997 models.
    Your 97 should have the 562 casting heads that flow a little bit more than the heaver casting heads on the earlier models. That being said the earlier heads are a little more durable and have more material in them for porting. Most 562's will flow in the low to mid 230's at .500 with just a good valve job on them.
  4. mgd1790
    1,051
    29
    Nov 25, 2003
    Suburban Chicago
    Thanks for the posts!
    Are the heads from the 97 to the 94 a swap or is there any modification required?
    Also, since it sounds like I have to switch out the timing cover, is a new chain in order (potentially) if the motor (94) has 85-90k miles on it?
  5. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,877
    585
    Aug 11, 2010
    erie, PA
    a 94 LT1 is worth a TON parted out...aluminum heads, roller cam, roller lifters, timing cover, water pump drive, optispark drive, lifter spider, dogbones, throttle body, power steering pump & pulley, fuel rail, smog pump etc etc all sell for GOOD money
    I buy "junk" LT1s every chance I get to part them out...guys will buy used pistons/rods...pretty much every part other than the block will sell
