a bit upset
Discussion in 'Engine Topic' started by americanhandy, Aug 16, 2012.
Thread Status:
Not open for further replies.
  1. Odin
    Odin Member
    40
    Sep 15, 2003
    American Handy - Look at how the link is bent. The arrows are there to ensure the lifters are turned properly to mate with the cam lobe surface. The link is bent wrong for the lifters to be installed in those holes. The rollers weren't parallel with the cam and rapid wear occurred until the catastrophic failure of the link.
    I'm sorry you had this problem.
  2. 1971SS
    1971SS Veteran Member
    724
    Feb 5, 2011
    eastern NC
    there's a reason for that arrow...and a reason it should be pointed up...
    notice the angle of the bends of the two bars...the one on the left shows the creases of the bends closer together at the bottom of the bar, and those creases are angled for a reason too...this is the offset that's built into that bar for the staggered lifter bores..when you or your builder installed the lifters with that bar flipped, it disturbed the offset and caused problems...
  3. Mr.Bill
    Mr.Bill Veteran Member
    440
    Apr 28, 2012
    Sparks, Nevada
    I just did a comp cam retro fit of a roller cam and lifters in my 468, It says in the instructions that the arrow must point up and the cross bar facing the valley, They are made to work only one way and you had it crossed and it broke, I think you owe Howard's Cams an apology.
    It wasn't their fault at all. Install error.
    I am sorry for your mis-fortune.
    When installed with the arrow pointing down the geometry is wrong plain and simple and not the way it was designed to work.
  4. Cardinal
    8,333
    61
    Jun 22, 2003
    Endicott, NY
    I'm a little confused by the term "upsidedown" being used to describe what we're seeing.
    I think I would say that they lifters were reversed from there proper locations in the lifter bores of the block. In other words, the lifter that should have been installed on the intake lobe of the cam was instead installed on the exhaust lobe of the cam which would them put the lifter that should have been installed on the exhaust lobe on the intake lobe.
    Because that happened the roller of those two lifters were out of alignment with the cam's lobe surfaces = carnage!
    Those lifters didn't jump out and move from one lifter bore to the other by themselves. Whoever installed them screwed up ROYALY!
    ASSUMING that the builder assembed the engine (including the valve train) HE is responsible for it and should be bending over backwards to make things right with you buy rebuilding what parts that you can salvage into a new motor FREE OF CHARGE to you.
  5. Marks71BB
    11,834
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    Because the link was installed incorrectly the lifter wheel was not 'tracking' the lobe of the cam. The cam was toast before the link failed.
  6. KEVS79
    KEVS79 Veteran Member
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    You would have thought if the pics were sent to Howards they would have pointed that out. I know absolutely nothing about roller lifters and that is the first thing I saw when I looked at the pics. That was before everyone else pointed it out. I didn't want to state the obvious since I really knew nothing about the subject.
  7. 79ZED
    79ZED Veteran Member
    3,108
    13
    Jan 31, 2000
    Nanaimo, B.C., Canada
    You have to wonder with the lifter set installed incorrectly and the resultant cam wear why the owner never noticed a lot of valvetrain noise long before the tie bar broke......
    John
  8. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    Can you install the pair of lifters with the brace on the block side? I was also wondering when the pair are not in the block bores can you flip the roller lifters in the brace to swap up and down?
  9. Mr.Bill
    440
    Apr 28, 2012
    Sparks, Nevada
    They can install with the brace facing the cyl, But that isn't correct, And yes you can flip them around, They always mount with arrow up and the brace facing the center of the engine so the lifter tracks on the cam lobe right..
  10. americanhandy
    americanhandy Member
    96
    Feb 19, 2011
    western NY
    pics. were taken after the valve train was disasembled and set there for the pic. the gouge in the block was from the link binding aginst it.
Thread Status:
