a bit upset
Discussion in 'Engine Topic' started by americanhandy, Aug 16, 2012.
Thread Status:
Not open for further replies.
  1. Mr.Bill
    Mr.Bill Veteran Member
    440
    Apr 28, 2012
    Sparks, Nevada
    So, Have you brought this up with your builder yet? He owes you big time.
  2. rydeer
    rydeer Veteran Member
    691
    Feb 28, 2012
    south NJ
    The broken link would not have reached that side if they were install properly.
  3. 73Camaro383
    73Camaro383 Veteran Member Lifetime Gold Member
    2,288
    Oct 29, 2010
    texas
    Looks like a builder screw up to me. As they sit in that pic, they are clearly installed wrong.
  4. ctchap70
    ctchap70 Veteran Member Lifetime Gold Member
    1,469
    Apr 29, 2002
    Fort Necessity, Louisiana
    Im inclined to believe the folks on here and their explanation. If it turns out to be the engine builders fault, you should put his name out there if he doesn't make it right. Then you should apolajise to Howards.
  5. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,328
    Aug 21, 2002
    Central Coast, CA
    Too many people are quick to bash a company; but never give the proper kudos or respect that may be deserved as well. Just 'letting the issue drop' isn't fair as the complaint is already out there, unfounded as it may be.
    The OP said this is not a new complaint regarding Howard's Cams, at least that's what he heard from someone else.
    However, I 'think' I know the story here well enough that I can say that if this hadn't been documented with the pictures, then this would be another 'complaint' .... makes me wonder about these other 'issues' with Howards... might not be fair at all to judge the company for builder f-ups.
  6. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,566
    23
    Feb 11, 2009
    Kentucky
    I'm still not sure I want to write off them for my cam yet. I'd like to hear this out more?
  7. CorkyE
    11,316
    877
    I think there's a whole bunch of us with Howard's products and no problems than the other way around.
  8. 1971SS
    1971SS Veteran Member
    724
    Feb 5, 2011
    eastern NC
    exactly!
  9. Odin
    Odin Member
    40
    Sep 15, 2003
    I think AmericanHandy is pretty sure by now what happened. Maybe he'll update us soon and set the record straight.
    We've all made mistakes and some have been big ones. The important thing is to learn from them and move on as wiser men.
  10. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,656
    30
    Oct 11, 2004
    NORTHEAST
    If what I am seeing is correct those lifters are not intended for cams over 230 @.050 Those lifters have .700 wheel and the rollers are enclosed by the body of the lifter. Those lifter are pretty much a stock replacement application.
    The lifter you want have a .750 wheel and the roller is not enclosed
Thread Status:
