a bit upset
Discussion in 'Engine Topic' started by americanhandy, Aug 16, 2012.
Thread Status:
Not open for further replies.
  1. HyPer
    HyPer Veteran Member Lifetime Gold Member
    738
    Mar 19, 2012
    Central Mississippi
    Ok, there's evidence showing backwards install. Look at the lifter with the bridge still attached, the circular piece that holds the bridge to the lifter is damaged in 2 places on it's edge, that's most likely what hit the block. When installed correctly, the bridge would not have been long enough to hit the block on the other side of the adjoining lifter. It was simply installer error, and that cam lobe being washed only in the center tells you it was caused by a roller lifter's wheel being at an angle to the lobe, versus running inline.
  2. ctchap70
    ctchap70 Veteran Member Lifetime Gold Member
    1,469
    Apr 29, 2002
    Fort Necessity, Louisiana
    Anymore news? Curious minds want to know.
  3. Notalent
    Notalent Veteran Member
    498
    Jan 27, 2010
    Dallas/LBC
    This is what I am thinking as well as possible install error....they look like the OE replacement lifters.
    To the Op, what are the engine specs, cam size etc???? Need to figure this out asap so we can delete this thread thad is SLANDERING HOWARDS!
    Howards is a 100% stand up company and Robert and the boys are the nicest you can come by. They will 100% stand behind there product. For those who are contemplating Howards, dont. Quality is bar none some of the best out when the parts are used in the PROPER APPLICATION. Most of our stuff is Howards product and we have never had a problem. The only reason they are priced cheaper than most, is that they dont advertise like Comp, Lunati, etc....this keeps cost down for the customers, so dont think theat because they are cheaper they must be bad...they just look out for the customers.
  4. ctchap70
    1,469
    Apr 29, 2002
    Brandon, you are absolutely correct. The OP should put a end to this if he has figured out he has made a mistake. It's not fair to leave it hanging in the air like this. Any Internet search for Howard's cams will bring up this thread. If op has more info or proof it's not builders fault he should post it. Maybe the OP is the builder?
  5. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,207
    19
    Jun 10, 2001
    Selah, WA
    Like everyone else has said, they were installed wrong.
    It does seem like they printed the words on the link bar upside down though as no matter where you put it it would still read upside down.
  6. Odin
    Odin Member
    40
    Sep 15, 2003
    I'm pretty sure you could just spin both lifters around to correct the problem.
  7. Marks71BB
    11,834
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    It's a little late for that now :crazy:
    but yeah, it would have done a world of good if done in time.:cool:
  8. Todd80Z28
    11,857
    424
    Jun 11, 2002
    Northern VA
    Flip the right lifter over top of the left one, and they are fine.
    Thats a big oops! I feel for you, but it's pretty clear from the photos that this isn't Howard's problem.
  9. Rich Schmidt
    Rich Schmidt Veteran Member
    4,285
    40
    Mar 27, 2010
    Denville NJ
    $12k for an engine built using a stock block and budget lifters,and what look like fairly conventional heads??? This guy should be mad at the builder anyhow.
  10. 79camaro2001
    4,784
    May 4, 2003
    Monroeville, PA
    Ya'll also missed one other crucial evidence, the wear mark on the bar indicating the bar and lifter was in a bind.
Thread Status:
