a bit upset
Discussion in 'Engine Topic' started by americanhandy, Aug 16, 2012.
Thread Status:
Not open for further replies.
  1. 79camaro2001
    4,784
    May 4, 2003
    Monroeville, PA
    Looks like you caught it too. I didn't have to blow up the picture to see it either.
  2. Bikefixr
    Bikefixr Veteran Member Lifetime Gold Member
    1,838
    111
    Mar 13, 2006
    I also see a lot ofvertical wear mark on the lifter body. That's caused by severe side-loading. If the lifter is dropped in incorrectly, it will roll, and the engine will turn fine by hand. But the roller is scrubbing across the cam lobe about 15degrees off parallel. The lifter body shows marks where the link bar was scuffing across the machined upper body portion. That link broke at it's weakest point because there was side loading and it fatigued. It won't last long with a lifter twisted in the bore. The metal is heat-treated and hardened. It will not tolerate any bending loads without failing. The lifter failed because the builder dropped the lifter in wrong and the link was causing the lifter to sit cockeyed in the bore. The builder needs to own up here.
  3. Dallas70
    Dallas70 Veteran Member
    180
    May 26, 2012
    Dallas (Frisco) Texas
    My gosh....if CSI Miami ever needed a forensic engine expert, this sure is the place to go! You guys never cease to amaze me with your expertise on this forum.
  4. HyPer
    HyPer Veteran Member Lifetime Gold Member
    738
    Mar 19, 2012
    Central Mississippi
    I agree, this thread needs closed/deleted.
  5. Marks71BB
    11,834
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    I disagree, it's run its course and Howards was vindicated.
    The OP needs to chime in with an update and an apology. I'd like to hear from the engine builder as well but we all know that will never happen.
  6. HyPer
    738
    Mar 19, 2012
    Central Mississippi
    Well, the reason I say deleted is because I myself have sometimes been in a hurry to check online rep of a company, so I google, find a thread like this, read the OP and maybe a couple posts following it, then decide on that. The OP should be updated with bold lettering stating that this problem being Howard's fault was debunked.
    I also agree that the thread starter should update and apologize to Howard on here for posting this thread.
  7. Marks71BB
    11,834
    Aug 25, 2002
    Good idea! maybe a mod could add an addenda with a synopsis.
  8. Mr.Bill
    Mr.Bill Veteran Member
    440
    Apr 28, 2012
    Sparks, Nevada
    I think the guy that posted this thread isn't going to give Howards an apology, He has had plenty chances to do so and he refuses to do so, He still hasn't faced the fact that the prob was the install plain and simple.
    I would also like to know how this caused 12000.00 worth of damage?
  9. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,328
    Aug 21, 2002
    Central Coast, CA
    Great minds think alike... so how did you think this up? :crazy:
    I, as well, would like to see the OP come back, but looks like that's not happening.
    Fortunately, the answer to the alleged issue was identified immediately. EDIT-I deleted a few posts so that the responses could follow up right behind the allegation. Just a clean up for search results.
    I'll lock this, if an interested party would like to respond, PM me so that I can unlock it.
Thread Status:
