A/C delete firewall panel
Discussion in 'Body Restoration' started by sladeballz, Nov 21, 2020.
  1. sladeballz
    sladeballz New Member
    11
    Sep 28, 2020
    1970 camaro. Want to delete the factory a/c but retain the factory heat and heater hoses. Can someone recommend an a/c delete firewall panel that'll work? The Detroit Speed panel doesn't appear to be heater hose friendly...
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,722
    714
    May 19, 2000
    Los Angeles
    I just grabbed some sheet metal and band saw and cut out my own. Super cheap and its worked for the last 20 years or so.
    Later on cut some holes in it for the AC lines when I put in the CAA system.
  3. badazz81z28
    19,215
    1,091
    Alabama
    American Graffiti AC Delete box.
  4. Zspoiler
    Zspoiler Veteran Member
    3,779
    366
    May 6, 2012
    Federal Way, Washington
    image2.jpg There are delete panels out there and on my 1979 Z-28 .I used a standard heater box .And drilled holes to fit
  5. NOT A TA
    NOT A TA Veteran Member
    362
    160
    Feb 12, 2009
    Delray Beach Florida
    I deleted the under hood AC stuff in my '70 bird before they made the AC delete blower boxes so like Zspoiler I made a custom box out of a standard one. I've since deleted all HVAC (because race car) and the modified box is sitting in my dining room , could be yours cheap! I'd replaced the blower motor on it but it only got turned on for the defroster maybe a couple times.
  6. badazz81z28
    19,215
    1,091
    Alabama
  7. Zspoiler
    3,779
    366
    May 6, 2012
    You just use a piece of sheet metal to fill in the space . And if you do it right you don`t notice it,
  8. GoldenOne7710
    5,311
    717
    Jun 23, 2004
    Athens, GA
    IMG_20121013_123026.jpg Got this one from Rick's/Ecklers. Don't remember the brand on the box, but the fit was good...fairly straightforward install.
  9. badazz81z28
    19,215
    1,091
    Alabama
  10. GoldenOne7710
    5,311
    717
    Jun 23, 2004
    Athens, GA
    AGM...That's exactly what I have. I remember now it had a small AGM decal on the inside of the plastic panel.
