a one piece spoiler trunk lid different then a 3 piece holes?
Discussion in 'Body Restoration' started by tuff57, Oct 2, 2008.
  1. tuff57
    tuff57 Member
    85
    Feb 23, 2006
    i have a 72 camaro and i owuld like to put the one piece 70 spoiler on it i bought a repro didnt match the holes on the stock lid (3 piece spoiler came off) and then i bought an original and same problem
    is there a difference in the lids?
  2. TommyRS70
    TommyRS70 Veteran Member
    1,228
    119
    Jan 31, 2004
    KY
    Just the holes for the spoiler.
  3. krabben1
    8,222
    64
    May 16, 2007
    ( . Y . )Delco
    The repro should have other mounting bosses for the studs,try measuring them first.If it works out,pull the studs(coarse screw threads)and mix up some fiberglass resin,pour in new holes and then screw in the studs.If not,weld up the old holes,drill new ones.Good Luck.
    P.S.The spoiler box makes an excellent template
  4. Fbodywarehouse
    Fbodywarehouse Veteran Member NastyZ28 Sponsor Lifetime Gold Member
    2,419
    9
    Mar 7, 2006
    If ya go to the OER one pc spoiler give us a ring as we can save ya some green when ordering one. Also feel free to call as I think I have one on the shelf and can check the mounting tabs for you.
  5. SCURRY
    SCURRY Veteran Member Lifetime Gold Member
    364
    Aug 20, 2004
    Vidor, Texas
    No there not, the holes on both edges are off, all the center holes are the same.
  6. flowjoe
    7,990
    30
    Feb 7, 2006
    SoCal
    Here's one data point for you: I have a '71 that was drilled for a three piece. The spoiler is long gone now...I picked up a used GM one piece spoiler and its studs line up with the holes in the deck lid - as drilled for a three piece.
  7. tuff57
    tuff57 Member
    85
    Feb 23, 2006
    thanks guys figured it out today and got all the holes in right spot!:cool:
  8. Solid71Steel
    Solid71Steel Veteran Member
    113
    Nov 23, 2007
    Florida
    actually on this note, i have the OER 1 piece and i havent installed it b/c i had a trunk lid w/o a spoiler on it and i dont know any of the measurments, i dont wanna just guess the distance front to back and drill, anyone have the assembly guide page for that?
  9. Orange71
    Orange71 Veteran Member Lifetime Gold Member
    3,792
    Jan 31, 2001
    Finksburg, MD
    Tall 3-piece spoiler:
    Short 1-piece spoiler:
    Mine originally had the tall spolier. When I swapped to the short one the outside holes were different which agrees with the above diagrams. All other holes were the same.
  10. TDWZ28
    TDWZ28 Veteran Member
    332
    Feb 8, 2004
    Michigan
    Orange 71...Did the short spoiler cover the holes from the 3 peice one? Or did you have to fill them?
