Aaron's 76 Type LT Project
Discussion in 'Project Progress' started by 76_TypeLT, Aug 1, 2008.
  1. olstyle
    olstyle Veteran Member Lifetime Gold Member
    8,501
    Jan 27, 2008
    Crestwood IL.
    Aaron I think those MSD coil covers would look great on your engine.
  2. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
  3. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    BTW, I have to replace my control arms, the lower ones in particular, in order to use coilovers. The PTFB arms I got a few years ago are made for traditional spring/shock installs. I will be listing those for sale. Custom Works helped me out on the new control arms that are designed for coilovers.
    So the money pit continues to drain the wallet. The pit is insatiable!!
  4. speed_m5
    speed_m5 Veteran Member
    1,099
    25
    Apr 17, 2010
    Baytown Texas
  5. JohnL71RS
    JohnL71RS Veteran Member
    1,688
    66
    Apr 12, 2010
    Marrero, LA
    I used my stock lower arms with my coil overs. I only replaced top to look and handle better, plus save weight.
  6. jester0618
    jester0618 Veteran Member
    271
    26
    Dec 6, 2015
    Bryan, OH
    I'm using the stock lowers as well, with most likely the Custom works uppers. I thought about replacing the lowers, but the gain doesn't justify the cost to me.
  7. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    The concern Keith has, which I think is valid, is the t-bar for the coilover needs to go INSIDE the spring bucket since you have a lot of weight on that shock t-bar, rather than mount on the underside of the spring bucket. The t-bar might be able to fit inside the stock lower control arm spring pocket, but it definitely did not on the PTFB arms. The PTFB pocket was ~1" too small.
    Hey, at least I get to try out some new control arms....:screwup:
  8. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    I got the engine wiring harness mounted inside the cabin, got the ECU mounted and got the HVAC evaporator mounted. I wrapped the wire loom with anti-rattle pad from Second Skin Audio. This was a bigger PITA than I had expected, but I am glad I got it done. I used "nyloc" nuts and lock washers to make sure these things don't come loose later. I got some stainless steel wire loom clamps off ebay to hold everything in place.
    I had to get a few more wire terminals so I can shorten the gas pedal and install the starter solenoid wire.
    I am going to tackle the fuel system next. I bought a gently used Rick's Tanks fuel tank from another member on the site for the LS. It was made for the 75-81 and has the width has been reduced for a mini-tub, which I am not doing. So I will have a little smaller fuel tank (like 18 gal). It already has a Walbro 255 in-tank fuel pump. I am looking at one option for the venting system, which I will know more in a few weeks.
  9. jester0618
    271
    26
    Dec 6, 2015
    Bryan, OH
    Wow, looking great
  10. Da-bigguy
    5,847
    1,819
    Jan 19, 2010
    Cypress, TX
    The underdash wiring looks fantastic! Nice and clean, just the way it should be.
