Aaron's 76 Type LT Project
Discussion in 'Project Progress' started by 76_TypeLT, Aug 1, 2008.
  1. jester0618
    jester0618 Veteran Member
    271
    26
    Dec 6, 2015
    Bryan, OH
    I'll look closer at painless for mine. AAW does lack a tad in instruction depth, but once they are separated into sections, goes pretty easy.
    I went to Painless' website. Very impressive set of instructions. Shame that at the price, that the window/door lock harness is an additional 250 bucks. Makes for a $1000 kit. AAW isn't very clear on whether it's included.
  2. JohnL71RS
    JohnL71RS Veteran Member
    1,688
    66
    Apr 12, 2010
    Marrero, LA
    i went with American Autowire. i think around $200. i just have to pay my friend a few buck and beers to connect it all.
  3. hot72rod
    3,023
    40
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I can take a look later on today and see if my AAW harness includes the power windows.
  4. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    Painless kit is definitely not cheap, there is no question about that. :eek: If I am not mistaken, AAW requires the harness to be constructed, whereas the Painless kit is already built and essentially mirrors what would have gone in the car, down to the wiring color, etc. One kit isn't any better than the other, so just pointing out the biggest difference between the two. AAW has the benefit of allowing the customer to create a truly custom install. Painless kit assumes you are doing an OEM-style wiring install, which is probably the case for most people.
    I am happy to take any detailed pics of the Painless kit for anyone who needs extra info.
  5. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    1,030
    23
    Apr 27, 2010
    Verona, ITALY
    Thanks for the info about Painless vs. AAW: I'm in the (mental) process to decide which choose..
  6. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    Sure, glad to help. I can only speak in depth about the Painless kit but will be honest with the feedback, not just because I bought it. ;)
  7. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    I've been piddling around but wanted to share a few pics of some pic-worthy work.
    I got the fuel tank pump and sender unit wired up at the tank so I can get the tank installed and plumbed.
    I had to swap out the lower control arms so I could use coil overs. I went ahead and swapped out the upper control arms with some adjustable SPC arms.
  8. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    I am taking off next week so I hope to get a lot done. The immediate plans are to get the fuel line installed and get more wiring/electrical installed. That would leave me with the brake lines as the major mechanical item left.
  9. giggity
    giggity Veteran Member
    1,612
    407
    Mar 18, 2013
    Pearland, texas
    OOOOO, i like that tank, I thought about buying an aftermarket tank, and probably could have with what ive spent on fuel pump, filters and sending unit. How much was this bad boy, if you dont mind me asking?
  10. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    I bought it from another member here who used it very lightly, so I did not buy it new. I paid ~$900 shipped (it was in the $900s), which included the pump and sending unit. You can modify a new OEM tank with a quality in-tank pump for $400-500 all-in ($150 for the tank, $250 for the pump, $40 for a weld-in recess). I still need the filter/regulator and all the lines/fittings. So you probably spent way less than me and got a tank that is as functional as mine.
    I fully admit I bought this tank because it's pretty sweet, not because it was necessarily a great value, lol :D It's a Rick's Tanks brand tank, fyi. It was also a custom made tank that's been narrowed.
    Spectra and Tanks Inc make 74-77 fuel injection ready tanks, among other companies. 70-73 and 78-81 are pretty easy to find.
