AC Pro for initial AC servicing ??
Discussion in 'Camaro Questions' started by badazz81z28, Feb 10, 2019.
  1. badazz81z28
    21,031
    1,484
    Alabama
    I have all the stuff to do it the traditional way, but AC pro looks simplistic and I don’t have to worry about left over cans or weight of the AC,
    Anyone do this before?
  2. ULTM8Z
    ULTM8Z Veteran Member
    10,182
    930
    May 19, 2000
    Los Angeles
    what system are you running?
  3. badazz81z28
    21,031
    1,484
    Alabama
    Vintage Air
  4. ULTM8Z
    10,182
    930
    May 19, 2000
    Los Angeles
    I imagine they're just like CAA... put in 24 oz and be done with it? In which case, it seems to me that any can of R134a should be fine? On mine, I just got two 12oz cans and dumped it in. I back checked the pressures to verify and they were good.
    Just verify that your compressor comes pre-oiled, in which case, ensure you get refrigerant that doesn't have any added oil.
  5. twozs
    twozs Veteran Member
    8,817
    174
    Aug 5, 1999
    hopewell jct ny
    No vaccum ?
  6. badazz81z28
    21,031
    1,484
    Alabama
    No I would evac the system like usual. Just instead of hooking up my manifold and loose R134 cans....use the AC pro with the low pressure port/gauge/hose can in one.
  7. twozs
    8,817
    174
    Aug 5, 1999
    hopewell jct ny
    you’ll still have to weigh the charge . I doubt that 1 or 2 cans plus oil will turn out to be the exact weight , but you may get lucky . You’ll need a set of gauges to pull a vaccum anyway and there are brass fittings to connect a regular set of gauges to a regular 14 oz can of gas . You can get a 14 oz can without the funny top for about half the price .
  8. twozs
    8,817
    174
    Aug 5, 1999
    hopewell jct ny
    C09DB948-1197-4E20-9A50-C453F78C1022.png and that’s the can of AC pro without the gauge
  9. badazz81z28
    21,031
    1,484
    Alabama
    But how do you know how much to put in? VA has a specified amount, but they don’t know how long all my hoses are or what size compressor im using.
  10. twozs
    8,817
    174
    Aug 5, 1999
    hopewell jct ny
    Hose length loss is unimportant it’s so small . Probably about a 1/8 of an oz. your only using 1 hose . Fill with correct amount in the directions . You have to be very close . Compressor only holds a fraction of the charge mainly oil . That’s why sight glass charging is the best way . You’ll know if it’s overcharged as it will flood the compressor with liquid Freon .
